Results 1 to 14 of 14
Thread: pool pump impeller housing needs a replacement
    Apr 2011
    Houston, TX, USA
    105
    hi all,
    my pool pump impeller housing is leaking water and I need to replace it. i was wondering if anyone can offer me any advice on where i should get one of these? would leslies or pool warehouse offer good prices?
    btw, i think i caused this leak some time ago when i overtightened one of the bolts and i might have broken the threads..thus the leak
    i am attaching 3 pictures here.
    -first is the model of my pump
    -second is a picture with an arrow where my leak is
    -third is the manufacturer label for the impeller housing (not very clear i know)
    14500 gallon plaster pool (replastered in May 2009) : 32ft.L x 4ft.D x 14ft.W
    Pentair FNS Plus 48 sqft DE filter
    Polaris 280 at 2hrs per day (retired now) & Aquabot T-Jet Turbo used as needed
    Circupool RJ30 SWG set at 80% output & Pentair SuperFlo 1hp 2speed running 6-8 hrs/day in the summer
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: pool pump impeller housing needs a replacement
    Unless you can actually see the cracks, those leak locations could be due to the gaskets and seals. A seal kit may be all you need.
    Mark
    Apr 2011
    Houston, TX, USA
    105
    thanks for the quick reply mas985. However, one of my problems is that one of the screws does not tighten all the way (the other 3 are fine). would a new seal kit fix that?
    mas985's Avatar
    Pleasanton, CA
    11,743
    If you stripped a thread, then you might be able to fix the thread by re-tapping the hole and putting in a thread insert.
    Mark
    Mar 2011
    Scottsdale, AZ
    406
    Water doesnt flow through that part, it cant really leak on top, that water must be coming from somewhere else.
    Probably need a new shaft seal, and seal plate gasket.
    The stripped thread issue is another issue all by itself. Once you get it apart you can better know what needs to be done to fix it.
    Here is a parts break out, with some pricing.
    http://www.inyopools.com/pool_parts_...hydropump.aspx
    Apr 2011
    Houston, TX, USA
    105
    Just-a-PB this is awesome. thanks for the details. if water does not flow from there, is there an easy way i can identify from where water is leaking? any tricks?
    Apr 2011
    Houston, TX, USA
    105
    ok guys, I think I need a little bit more help. I opened the housing today, and the leak is about 1.5 inches to the right, right underneath the location where the tube goes upwards.
    a thread insert would not work since it would be hard to file the plastic and put an insert in.
    I am also attaching a picture of the inside of the housing. I don't see where a seal would go. the only thing inside there is an O-ring. should it have had a seal as well?
    mas985's Avatar
    Pleasanton, CA
    11,743
    Did you look at the drawing that PB posted? The seal is on the motor shaft next to the impeller, call out #19.
    A seal kit will have the o-ring, seal and any gaskets the pump might have. But if the housing is cracked, then a seal kit won't help.
    Also, you don't file anything for an insert. You would drill out the hole, tap the hole and then put in the insert. Like this:
    http://www.repairengineering.com/helicoil.html
    Mark
    Apr 2011
    Houston, TX, USA
    105
    ok I replaced part 19, the shaft seal, but water is still leaking from the same place (basically 1.5 inches to the right of the location indicated in the picture). Do I need to replace the entire volute reinforced plastic? http://www.inyopools.com/Products/07501352028452.htm
    is it even worth it at this point, given its $180 cost, or I should get a new pump? I saw some brand new pumps that might fit my cramped up space and old piping.
    Hayward Super 2 Pump, 1.5 H.P at $389 [buy.com] - 1hp for 315 [americanbestpoolsupply]
    Pentair Whisperflo Energy Efficient 1hp at $410 [bestbuypoolsupply] --> this might not be the full rated version
    Pentair 1hp SuperFlo Pump at $295 [ezpools, bestbuypoolsupply]
    mas985's Avatar
    Pleasanton, CA
    11,743
    It depends on where the leak is located. If it is leaking where the volute connects to the seal bracket, then it is probably the gasket or the bolt you stripped. Have you fixed the threads yet?
    If you would rather just replace the pump, then given the size of your pool, the Superflo 1 HP would probably be your best bet and it is at a good price point. Just make sure you get a two speed.
    But just a FYI, 11 hours is way to long to run any pump unless you are cleaning up after a storm or running on low speed. Normal operation should not require that much run time.
    Mark
    Apr 2011
    Houston, TX, USA
    105
    thanks mas985!
    What would the two speed pump give me over single speed? I usually run my pump around 6hrs in the winter, but with the super hot weather in the summer and my SWG, I needed close to 10 hrs in the summer to maintain the pool clean.
    I did not fix the threads yet. I need to go get the helicoil [however the leak is nowhere near the bolt I stripped - I stripped the bottom right bolt]
    yes the leak is exactly where the volute connects to the seal bracket. by gasket you mean part #16?
    Apr 2011
    Houston, TX, USA
    105
    Any chance the multi port valve is at fault?
    Prior to replacing the seal, it would only leak water on filter mode. On recirculate the pressure was less and with no leaks. Now after I replaced the ceramic seal, it leaks from the same place on both recirculate and filter modes
    mas985's Avatar
    Pleasanton, CA
    11,743
    Lower energy costs and better filtering.
    I don't understand why this would be the case. Your SWG is sized appropriately for your pool so again, you shouldn't need that much run time. Exactly what is occurring that makes you think you need that much run time?
    Yes. But did you get a seal kit or just the seal when you replaced the seal. All of the o-rings/gaskets should have come in the seal kit allowing you to replace everything.
    At fault for what? It wouldn't cause the pump to leak.
    Mark
    Apr 2011
    Houston, TX, USA
    105
    Pool warehouse told me the multipart valve might be next in line in terms of the next part that needs replacement and might be responsible for this leak. I asked you guys because I could not comprehend how that could be contributing to this issue. [he said it might be building up pressure - I did not believe him]. Yes I got the seal kit and they replaced it for me (I could not see what they did since the pool warehouse guys went in the back to do the work) including the ceramic seal and the o-ring.
    thanks for the info on the new pump.
    As for the number of hours I run my pump, it was just my previous pool guy's recommendation.
