Thread: closeing info
    closeing info
    I have to close my in ground pool but would like to know if the pool needs to be cleaned of all algea before I cover it .. my cover needs to be replaced so it doesn't stop all sunlight so algae grows at the beginning of the season anyway
    what is the temperature I have to close by before problems occur?
    Is it cheaper to clear up algae in a pool with a bunch of D.E. recharges or a shock of liquid chlorine?
    Its going to be about 44 degrees at night in about 2 days here
    21X41, 30,000, ig, vinyl,48sf de, 1hp hayward super pump, 2" piping, 2 skimmers, 1 main inlet, 2 return, built in 1988, no enclosure, lots of trees around, direct sun. Thanks in advance to all who have answered my questions.
    22,551
    Re: closing info
    If you want the job of cleaning it upon opening I wouldn't worry about it. Just deal with it next year. However if you want to open to a clean pool, perform the shock process till it's clean, get a new cover and close it properly. The water temp should be below 60F when you close.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: closeing info
    Shock it into submission and then cover it. I'm with Bama, get a new cover, opening to a swamp is no fun!
