Thread: Finished self install have test results NOW WHAT??
    4knights's Avatar
    NE Kansas
    419
    Salt 3010
    CYA 55
    FC. 0.5
    TA. 250
    PH. 7.2
    CH 270
    Water temp 63*
    Using the TF-100 with the lighted battery mixer and salt test stick want to balance the water before I bring to closure levels and close for the winter. Sad to sit on the deck knowing its finally done but y to cold to get in.
    So, in what order do I add/subtract items?
    My SCG is running at 60%
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    Re: Finished self install have test results NOW WHAT??
    You need more FC. So dump some bleach in, or crank up the SWG and get it to 3 or 4
    Lower TA some by aeration and acid. Directions are in pool school.
    38,303
    CYA is a bit low for SWG ... although may not matter as much in the winter.
    Get the FC up immediately with bleach and then let the SWG maintain it.
    You are going to have to watch the pH as it will likely rise fast due to the SWG and the high TA ... you may eventually want to work on lowering the TA (see Pool School article).
