Results 1 to 9 of 9
Thread: Numbers going a little crazy
    humrz28's Avatar
    Volusia County, Florida
    15
    Hi guys! I appreciate all the help I got when starting the BBB a little over a month ago. Up until now we have had great success and have been enjoying a nice clear pool. On average we had been holding steady at FC 8.5, CC 0, PH 7.2/7.4, TA 120-130, CYA 40
    On the 28th of this September our numbers started to change: FC 11, CC 0, PH 7.2, TA 100, CH 140, CYA 60
    Now tonight, the numbers are all sorts of crazy and I'm not quite sure where to go from here. Our numbers tonight are FC 17, CC 0, PH is off the charts, it actually turned to the color purple, TA 90, CYA 65.
    I can't quite figure out what is causing the sudden shift in numbers or how to get them back in line. Any suggestions?
    16' x 48" Round Intex Vinyl AGP
    Intex 56633EG 2500 GPH Pump
    Taylor K-2006 Test kit
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Numbers going a little crazy
    As the water gets colder and with less sunlight on the pool, you'll lose less FC each day. Are you testing before adding bleach? Or are you blindly adding bleach on the basis of previous use? I assume you don't have an SWCG.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    38,284
    +1 to above question.
    BTW, the pH test will read falsely high when the FC > 10ppm ... so ignore that for now.
    humrz28's Avatar
    15
    We would normally add bleach after testing, but because the FC has been so high we haven't added any in about a week. We do have a floater with 2 pucks that sit in the pool, I guess that could be counter productive. The smell of bleach has been a bit more prominent as well. While typing this something is telling me to take out the puck floater. We do not have an SWCG, just the 2500 Intex pump.
    Take out the floater! It is raising your FC and your CYA. Keep testing and you should see the FC start to drop.
    Of course, with a CYA of 65, your target FC is now 7.
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    humrz28's Avatar
    15
    Thank you so much!
    38,284
    A typical chlorine/bleach smell is due to CC ... not having high FC. Although there have been reports of people indicating a smell due to the pucks that goes away when they switch to bleach (and some films in the skimmer as well IIRC).
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I used a puck for a little while to add CYA. I noticed the bleachy smell. It disappeared when the puck was gone, so I figured that's where the smell came from. I kept sniffing the pool all summer when using the bleach and never got an odor from the water. Just once I smelled it otherwise, because I had gotten some on my hands, lol.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    My puck feeder feeds the stair returns. Before I took out the last puck even on the lowest setting that area smelled like bleach. I think trichlor just smells like bleach/chlorine/ etc.
    - Sent using Tapatalk
