Thread: Is it OK to use the circuit breaker to turn pump on and off?
    Sep 2011
    Atlanta Ga
    310
    I have a pool pump in the back yard, behind the pool. I have to walk outside to turn it on and off. I can also turn it on and off using the circuit breaker inside the house as a switch. Is there any problem with using the circuit breaker in that way?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Is it OK to use the circuit breaker to turn pump on and
    not really what a circuit breaker is designed for, it may cause premature ageing, but otherwise it is the exact same thing as switching it off and on at another point. Could you not put a timer onto the socket instead?
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    Sep 2011
    Atlanta Ga
    310
    No socket. It is 220 that runs from a cord in a box directly to the bump.
    27000 gallons
    Pool built in 1971.
    38,301
    So how do you turn it off outside if there is no switch by the pump?
    You could just add a timer or switch right by the breaker panel inside.
    Jul 2012
    296
    Jason pipped me at the post, I would in this circumstance isolate the circuit and add a switch after the circuit breaker.
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Dittos for Stuamarr, you shouldn't be flipping the breaker to turn the pump on/or, eventually the thing will fail and possibly start burning/melting, I've seen (and smelt) this very thing happen.
