Thread: Rubber plug, sizing question.
    Most of the rubber plugs that I have are color coded but I don't know what the colors mean, maybe they don't mean anything? Regardless, how do you know which plug to use in which size of line? My skimmer plug always seems to work, but I am skeptical as to whether it is the right size. It goes almost completely inside the pipe, which is maybe OK but seems odd.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Rubber plug, sizing question.
    the wingnut colors are somewhat new, it just makes it easier to read than looking for the tiny number on the plug. the plug should fit 3/4ths into the hole without any compression added. The plug you have will probably work but they are designed to stick out a bit.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
