Thread: Draining below returns. Then fill backup or not?
    Every year I make sure my water is balanced prior to closing. I also drain the water below the returns, blow them out and plug them. After that I always refill the water level to a few inches below the skimmer, which basically means adding another 8" of water or so.
    I refill it because the pool guy that taught me how to close said i needed the extra water in there I guess for weight. My question, is....why balance the water and than refill with water that is potentially unbalanced? It seems like taking a step backwards.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    22,551
    Re: Draining below returns. Then fill backup or not?
    I wouldn't drain and then refill. Why not just blow the lines and plug them as they're blowing. Use a gizmo in the skimmer and blow the line through it.
    I just happened to think, "I wonder if the reason I am supposed to fill it back up is to give the loop loc mesh cover more support when loaded with snow?" Is this a good reason to refill to below skimmer?
    10,000 gallon
    NC KANSAS44
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by Thinkly
    This is true. Also fiberglass pools are more susceptible to ground movement and freeze damage.
    As said above, blow the pool underwater from a gizmo in the skimmer.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    OP Mine's vinyl and the company that originally built it also says to bring level back up (or just eel it there as suggested.) They cited weight for wall support.
    Just wanted you to know I've been told the same
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
