Thread: Pressure Switch??
    Pressure Switch??
    So I by-passed he pressure switch and now it seems to work. I priced these **** things to find out the are $60. I have seen universal ones online. I have a h200. Are all univeral switches the same and is there a cheaper place to get these?
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Pressure Switch??
    A universal switch would work. Here is one on Amazon:
    http://www.amazon.com/dp/B004M623WG/?ta ... B004M623WG
    Or you can use this one as well. I prefer this one.
    http://www.amazon.com/Tecmark-Universal ... m_sbs_lg_2
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Now what is the difference between the 2? I have seen many universals but have no idea what the difference is between them. Thanks for the input.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Factory Warranty Station for:
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Quote Originally Posted by Pool Clown
    Make sure that the new switch is set for the proper pressure. Usually around 2 to 3 lbs. when the heater is at the same elevation as the pool deck.
    I have never had to adjust any pressure switch unless the pool sits up really high as compared to the heater. One example was a condo building where the equipment room was in the underground parking garage and the pool was at ground level.
    Paul
