Thread: Need suggestions for spa cover
    Aug 2010
    New Caney, TX 77357
    184
    Need a cover for our attached spa (below). It's nominally 6x9. Not interested in spending several hundred dollars (or more) for a custom made cover, at least not at this time.
    The intent of the cover is strictly to keep the spa clean of debris, not concerned with insulating properties. My idea was to cut some plywood to fit and stain it to match the nearby cedar pavilion/deck. My wife nixed that idea - "too heavy". So maybe we can use some kind of sheet foam but obviously needs to be thick enough to have some rigidity. I believe I have read that it needs to be covered with vinyl or something to keep it from breaking down from exposure to the elements and the humidity from the pool water.
    No idea where to obtain the necessary sheet foam and how to cover it.
    [attachment=0:1zf7ogc3]spa resized.jpg[/attachment:1zf7ogc3]
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: Need suggestions for spa cover
    Quote Originally Posted by Stevereno
    [attachment=0:329wh2mz]spa resized.jpg[/attachment:329wh2mz]
    Perhaps an auto upholstery shop could help you with both the foam and the vinyl?
    Aug 2010
    New Caney, TX 77357
    184
    Quote Originally Posted by YippeeSkippy
    [attachment=0f0v5dct]spa resized.jpg[/attachmentf0v5dct]
    Maybe so, any other ideas folks?
    Aug 2007
    near the swamp
    806
    marine ply coated in bedliner
    Qwaxalot's Avatar
    Jun 2012
    439
    .5" thick, closed cell foam, cut to fit. Will insulate and keep the **** out. Buy at store that overhauls furniture.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
