Quick question: My solar cover finally arrived, blue w/bubbles type. On or off while I'm in shock mode, or does it matter? I thought it might save me some chlorine if I keep it on.
if you keep it on all the time you lose the benefits of the sun on chloramines. I'd take it off a few hours every few days at minimum. This is entirely based on what I have read here not personal experience.SebringDon said:Quick question: My solar cover finally arrived, blue w/bubbles type. On or off while I'm in shock mode, or does it matter? I thought it might save me some chlorine if I keep it on.
I'll be taking it off for my wall-scrubbing sessions until everything is clear, and for using the pool, so it should have plenty of open time. Thanks for pointing out the chloramines issue.UnderWaterVanya said:if you keep it on all the time you lose the benefits of the sun on chloramines. I'd take it off a few hours every few days at minimum. This is entirely based on what I have read here not personal experience.SebringDon said:Quick question: My solar cover finally arrived, blue w/bubbles type. On or off while I'm in shock mode, or does it matter? I thought it might save me some chlorine if I keep it on.
- Sent using Tapatalk
SebringDon said:Got back from my trip away, and the pool looks even better. The black algae, if that's what it is, will be gone in another day or two. I shocked to 15 before I left and was still at 12 when I got back.
Thanks again for all the help from everybody, particularly Vanya.
SebringDon said:Final recovery numbers:
FC 4.0, CC 0, pH 7.5, CYA 20, TA 95, CH 320
CSI = .07
Now that I've got the pool cleaned up, I'll raise that CYA to 30 and leave the rest alone, I guess.
Thanks again for the help. I would have never gotten here without TFP.
UnderWaterVanya said:SebringDon said:Final recovery numbers:
CSI = .07
Fantastic!
Glad it all worked so well. Did you track how much bleach you used during the process? How many bags of debris - that sort of thing? An inventory of the nails, bags of leaves, etc would be interesting.
