Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Opinions Requested - Pavers or Concrete?
    Greetings Everyone. After lurking for a while, this is my first post.
    I live in Plano, TX and am thinking about having an in-ground gunite pool constructed. The hardscape design includes about 850 sq ft of deck. The pool is geometric and the deck lines are mostly rectangular.
    Stamped and stained concrete or pavers are under consideration for the deck.
    For a concrete deck (4 inches thick in center 6 inches at edges, 12 in O.C. #3 rebar), the pool builder's sub would apply a coat of sealer, then some silica to reduce slip, then seal again. Having looked at some representative samples with preferred colors, the appearance seems very nice.
    But, I've seen comments about cracks in concrete and subsequent gaps or uplifting. Summers here are hot; thermal expansion and control of moisture levels in the soil can be problems. I'd hate to spend a lot of money and then have problems three or four years later.
    I've also looked at pavers. Pavers seem like a nice alterative in that thermal expansion might be less of a problem. If sinking or swelling of the base and pavers does occur, repair is possible and sometimes relatively easy. Potential problems with weeds or ants could be easily controlled. But, having looked at Belgard pavers on the pallet at the stone yard, I can't say I am impressed with the washed out colors. Nothing in the yard looks like the pictures in the brochure, unless color enhancers and sealers are applied.
    So, I'd enjoy hearing the opinions of others regarding the two choices for deck. Or maybe you have one of these types of deck; how is it holding up? Did you experience any problems?
    Thanks in advance for any insight.
    Warmest Regards,
    Lizzy
    18,000 Gallon IG, Pebble Sheen, Quartzite coping
    Pentair 420 Cartridge Filter, 2HP Silencer, 400,000 BTU Heater, Platinum Legend Cleaner
    2x IntelliFlo VS pumps - Screenlogic Interface - Stenner 45MPHP10 15 Gal Bleach Injection
    TF100 + PoolCalculator + This Site!
    Clarksville, TN
    126
    Re: Opinions Requested - Pavers or Concrete?
    I am in he middle of a (self-build) pool now and I am going with pavers. Concrete will crack no matter what. Being a landscaper, I have installed lots of pavers and if the preparation underneath is done right, you'll have no problems. If you ever need to run more underground lines or a leak, you can just pull up some pavers and then replace when finished. I would recommend a low-gloss sealer to help retain the polymeric sand and enhance the colors. Also, the pavers at the yard are usually very dusty and look much better clean.
    34,000 gal., 20x40 Roman, IG Steel/Vinyl, 500# Hayward Sand Filter, 2HP Ecostar-VS, Savi Note LEDs, Autopilot Digital 220 SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I love concrete pavers. Durable, easily replaceable, available in a million shapes, size, and colors, and relatively inexpensive, at least compared to stone!
    Dec 2009
    Central Massachusetts
    2,690
    Pavers!
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jul 2011
    Hunterdon County, NJ
    32
    I just did pavers. The best part is if they get wavy or move in 10 years they can be picked up and reset without having to break concrete and start over.
    1971 Anthony 20x40 In-ground Vinyl, 1Hp Super Pump, 244t sand filter
    Big dreams, no cash, but a whole lot of creativity mixed in with little bit of stupidity!
    Oct 2007
    Valrico, FL
    542
    I also have pavers. Much better than concrete.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have a concrete deck that is finished with acrylic textured surface. It has been in place for seven years now. Very easy to clean and maintain. I rolled a new top coat on it about two years ago, it took a couple hours and cost about $100 in materials and supplies. Other than a few hairline cracks, we have had no problems. I used some calk to get rid those before recoating the deck. I went with the acrylic surface because I have a salt pool and have seen how many stone surfaces deteriorate and other surfaces show salt stains.
    I have used a lot of pavers in other areas of my landscaping, but for the area right around the pool we chose the acrylic finish and are happy with it.
    chiefwej
    Mar 2011
    Scottsdale, AZ
    406
    What about stone pavers, Travertine is my favorite. Nice and cool in the summer.
    Thanks for your replies. I do want to learn a great deal more before deciding.
    chiefwej: I agree that the acrylic coating over concrete looks good. Thanks for pointing out the advantages for a SW pool.
    Just-a-PB: Natural stone pavers including Travertine look awesome, but I was imagining the cost would be prohibitive. Then again, I've no clue.
    Warmest Regards,
    Lizzy
    Mar 2011
    Scottsdale, AZ
    406
    Travertine is $6.00 to $8.00 a sq ft in my neck of the woods.
    Were no closer to mexico then you guys.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Pavers eliminate the option to install a safety cover don't they?
    - Sent using Tapatalk
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by UnderWaterVanya
    Nope..plenty of saftey covers with pavers. Different anchor system.
    Jun 2012
    Mint Hill, NC
    2,589
    I was under the impression only some of the anchors could be in pipe. What systems work with pavers? My only exposure is loop-loc.
    Dec 2009
    2,690
    Nope, all of my anchors are in pipe. I have a loop-loc.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by bk406
    You're right!
    http://safetycoverpro.com/files/Install ... _Cover.pdf
    Pavers, brick, or stone: When decks are made with brick, stone or pavers laid on sand, or on a cement slab, the anchor-in-pipe method must be used or the cover cannot be considered safe and warranted. For each anchor to be installed by this method, you will need to use 3/4" inside diameter pipe or conduit with a minimum length of 15".
    Someone else on this forum had said that only a certain number were allowed but this clearly seems to say that you can use any number as long as they meet the requirements. Appologies for wrong info.
    I am glad i used pavers when i had to fix a leak this year. My anchors i used were the same as for concrete. Have not come close to a paver moving for any reason. However most of my pavers are 1' x 1' and 18" x 24".
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    Quote Originally Posted by Just-a-PB
    Forgive my ignorance Just-a-PB, that's the cost of the travertine paver only, correct?
    As in: labor, base, sand, sealer, edging, etc. not included in $6-8 per sq ft?
    We love our travertine pavers..paid about 11.50/sq ft installed...
    Charlotte, North Carolina, 30k, in-ground concrete (built 2001, remodeled 4/2012), PebbleSheen Blue Aqua, Polaris 360, Jandy 1.0 HP Dual Speed Stealth Pump, Stenner Pump 45MHP2 220v - 1/4" black tubing mounted on 15 gallon UV Gray tank, Jandy CV340 CF, CMP deck jets x6. TF-100.
    Mar 2011
    Scottsdale, AZ
    406
    I know, its sad but true.
    We purchase travertine pavers here for $2.60 to $4.50.
  20. Back To Top    #20
    Dec 2009
    2,690
    That would be $20 + per sq foot (materials and labor) here in New England.
