Thread: Grey Leslie's Power Powder Plus (Cal-Hypo)?
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    I stocked up on Leslie's Power Powder Plus packets about 15 months ago. It has been stored in a deck box under a protected porch near the pool. The product used to be white and granular. I opened some packets today and it is now grey and powdery. Any adverse effect on its efficacy or is that just the normal aging process (like DPD powder turning grey)?
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    Aug 2010
    Dallas, TX
    4,052
    Re: Grey Leslie's Power Powder Plus (Cal-Hypo)?
    I wouldn't worry about it, I'd use it, as long as your CH isn't already too high in the pool.
