Thread: Changing sand in filter
    I need to change sand in my filter, but can't get the dome off. I have the octagonal wrench, but can't remove. Any suggestions?
    25000 gal i/g vinyl liner with 1 1/2 h/p & sand filter
    Welcome to TFP!
    What brand/model of filter do you have?
    Fayetteville, Arkansas
    If you have a pressure gauge with a bleeder for clearing air from the system, you may want to see if there is any pressure built up by bleeding it. There may be enough latent pressure to make it hard to break free. Just a thought.
    20x40 30,000 gal IG Liner, Pentair II Sand
    Mine was hard to get off too. I used a semi-heavy rubber mallet hammer, put on the octagonal wrench, and carefully hit the handle of the octagonal wrench. It took a little while but it finally busted loose.
