Results 1 to 7 of 7
Thread: What is the prefered skimmer configuration?
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    132
    For a new pool build, what is the best skimmer configuration for an in ground pool?
    Should it have an equalizer line?
    Should the second hole be tied to the main drain?
    Should the second hole be plumbed with a backup line that is stubbed at the equipment pad in case the primary skimmer line gets clogged or damaged?
    My pool will be about 29K gallons with two skimmers.
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: What is the prefered skimmer configuration?
    Ideally, each suction port should have a home run line to the pad and skimmers should have an equalizer line to the wall.
    Mark
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by mas985
    Mark - why is the line to the wall important? Why is it even called an equalizer? I assume without the equalizer but with a main drain (home run plumbed) you would suck too much air even if both were enabled.
    - Sent using Tapatalk
    mas985's Avatar
    Pleasanton, CA
    11,737
    Two reasons for the equalizer line. If your skimmer becomes full of debris and blocks the flow, the equalizer will allow water to the pump.
    The second reason is when the water level drops below the skimmer, the skimmer float should block flow and again, the equalizer allows for alternate path.
    An equalizer isn't absolute necessary but they are not all that expensive to install either so given the choice, I would put it in.
    Mark
    Jun 2012
    Mint Hill, NC
    2,589
    Existing pool lacks one - but liner is old. At some point when the liner is replaced - you would deem this a worthwhile retrofit? Skimmer box has two outlets - one is plugged. Trying to figure out how hard this would be to accomplish in a retrofit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I probably would only consider doing this for a new pool unless you have had issues with the pump running dry.
    Mark
    Jun 2012
    Mint Hill, NC
    2,589
    Thanks Mark - that is one more thing I don't have to worry about for a while. LOL.
