Thread: Removing side panels from old spa
    Hi, I have a '95 Hotsprings Jetsetter with a slow leak that only seems to happen when the heater is running. A friend told me something with the heater is probably loose, but the only way to gain access to the area in question is to remove some side panels. The panels on this model (they are wood) do not have screws or staples that I can remove-they appear to be tongue in groove. Any ideas on how to remove them without damaging them?
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Removing side panels from old spa
    I'm not real familiar with HotSpring models going back that far but I've never seen a spa panel without screws. Are you sure they aren't covered?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Knoxville, TN
    41
    They are stapled and glued into place. Best way is to carefully pry them apart, or flip the tub on its side and go from the bottom. The foam on the underside is VERY tough and will cut you if you try to manhandle it out. I've used an angle grinder to cut sections of it out and poke and prod with a wood dowel. If the dowel comes out wet, you are in the are of the leak.
    Good luck! Leaks in hot springs spas are a PITA.
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
