Thread: Short Bonding Wire
    Short Bonding Wire
    Hi everyone....I am in the process of replacing an burned out pool pump. My problem is the bonding wire. It appears that the new pump is about 3" longer than the old pump in addition the bonding lug is located further back on the new pump. My problem is that I am unable to connect the bonding wire to the bonding lug because the wire is too short by approx 4". What is my solution?
    I thank you in advance.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Short Bonding Wire
    Get a short piece of #8 copper wire and attach it to the existing bond wire with bonding connector. You should be able to get these at any home center or good hardware store.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Thanks Qwaxalot....your response is greatly appreciated!
