Thread: Steel around underwater light fixture
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    For a long time I've been getting iron stains in the pool and could not figure out where it was coming from. I thought all the steel in contact with water was 316 stainless. Today I noticed the underwater light looked a little dark around the edge. I laid down and felt the ring that holds the fixture against the wall and it is rusted and badly pitted. The rust is not built up like it is mild steel and I could rub it off with my finger so it must be some iron containing alloy.
    Is it common to put that kind of retaining ring around an underwater light and can it be replaced while it is submerged?
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Mar 2011
    Scottsdale, AZ
    406
    Re: Steel around underwater light fixture
    Lights are on a cord, and can brought to surface to work on.
    Here is a video that might help.
    http://www.youtube.com/watch?v=vTO-wYmhpVU
    Feb 2008
    Denton, TX
    5,061
    Not sure how old your pool is but the fact that it is rusting isn't all that surprising. Different grades of steel do show up in light fixtures. Some stand the test of time and some don't.
    As Just-a-PB said, you can unscrew the fixture and pull it up to the surface since it will have plenty of wire for you to pull up to the deck. Then, you can identify the brand and replace the ring and the gasket.
