Results 1 to 7 of 7
Thread: Adding borax 3 weeks ago....now itching skin??
    lka674's Avatar
    Jul 2012
    Williamson County, Texas
    106
    FC 5.5
    CC 0
    TC 5.5
    pH 7.3ish
    TA 60
    CH 430
    CYA 60
    Borate 50
    We haven't been in the pool since before I added the borax on Sept 6 and yesterday my husband decided to get in for the first time. He does not know that I added borates, since I handle the pool and we really just don't talk about what I do or don't do. He was almost immediately complaining of his skin itching while he was IN the water and I too have noticed my arm itching when I go to get testing samples from under the surface.
    Anyone heard of borax causing this type of skin irritation IN the water?? I know in powder form it can cause eye and skin irritation, but I had always heard that adding borates to pool water actually made the water less likely to cause itching/irritation.
    Maybe it's not the borax at all but maybe my pH is a little lower than usual is causing it? I heard pH didn't start to cause irritation until below 7.2.....
    Thanks for any comments.
    LK
    Pool grand opening Sept 2010. 100% sun exposure. Beach entry with fountain, IG gunite pool, approx 11,000g. Hayward HK sand filter. Intelliflow VS 350 pump w/ max flow rate 160 gpm. Dolphin (cordless) M5 Liberty pool cleaner. The pool has waterfall at one end with a tanning ledge and a spa at the other end that has a spillway into the pool and there is a water shear falling from the pool equip wall into the spa. DH did a beautiful job of designing it himself!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Adding borax 3 weeks ago....now itching skin??
    It's the first report I can recall regarding any skin itching or irritation from borates in the water. Raise the pH to 7.5 or so and see if the problem persists.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Just out of curiosity, what kind of borate did you use, and where did you get it from? I wonder if it's possible there was some other type of additive?
    I use borates and have allergies/eczema and my borates actually have the opposite effect. At 50 ppm in theory it should actually leave your skin soft. Borates are used in a lot of skin products for a mild anti fungal effect.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Experiment suggestion (after increasing ph.)
    If your skin reaction persists, have a bath with a bath bomb and see if you have a reaction. Borax is main ingredient I most "holistic" bath salts and bombs.
    Another test: add a quarter cup to your laundry as cleaning booster. Wash some shirts. See if you or h. react to the shirts. Calculate how many ppm would be in the laundry.
    Borates leave the water with splash out and draining/dilution just like cya. If it turns out you actually are reacting to the borates, please let us know so we can warn people only to add if they know they're not allergic.
    Hopefully, you'll find that's not what it is.
    Helpful Links:
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by lka674
    FC 5.5
    CC 0
    TC 5.5
    pH 7.3ish
    TA 60
    CH 430
    CYA 60
    Borate 50
    LK
    I think it's very likely that your phenol red (pH reagent) is bad. get some fresh reagent and retest pH. I'll bet it's less than 7.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    lka674's Avatar
    Jul 2012
    106
    I used 20 Mule Borax and I purchased it from my grocery store, Qwaxalot was correct about the phenol red being bad....pH was very likely below 7, I've been aerating and will get hubby to get in the spa today to see if its better now that we r back up to around 7.4ish. Thank you all for comments and I'll let you know the final verdict. A good sign tho is that my arm isn't itching anymore when I'm taking my samples!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Excellent news! It's exceedingly rare to be allergic to borax and I was hoping that was not the case.
    Helpful Links:
