Thread: How do I determine my "turn over" rate ?
    Jun 2012
    Lafayette, Ca / USA
    260
    I keep reading about the importance of having at least 1 full "turnover" over water during the winter time, running the pump/filter less than I usually do in the summer swin season. How do I determine just what that amount of time is? (We live in a warmer climate so will keep water in the pool & the necessary levels of chems).
    I have a 40,000 (est) gallon pool with a 1/2 HP pump & 2 Cartridge filter
    Thanks
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    22,543
    Re: How do I determine my "turn over" rate ?
    I wouldn't worry about the actual number of turnovers you have. You don't need nearly a complete turnover each day in the winter. Just keep cutting back on the run time until it's not keeping the pool clear and then up it a bit and leave it there.
    Jun 2012
    Lafayette, Ca / USA
    260
    Got it ... Thanks .. (but I'm still curious about how to determine that if anyone knows).
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Without asking you about your plumbing set-up and assuming 40-50gpm you are looking at 8-10 hours run time for one turn on a 40K gal pool.
    Jun 2012
    Lafayette, Ca / USA
    260
    thanks
    38,251
    To answer your last questions, it is not "easy" to calculate the flow rate. Into that calculation goes: All the details of your plumbing (# suction and return pipes, sizes, eyeball sizes, # of elbows in the plumbing, etc), your pump, filter, and valve details, pressure readings (ideally the pressure side and the suction side), height of equipment relative to the water .... and probably some more stuff.
    Thus, easier to just cut the run time back until the pool is not clear enough for you and bump it back up. Chemical mixing happens very fast and is not a limiting factor.
