Thread: Is it too early?
    May 2009
    Trenton NJ
    497
    Is it too early?
    According to the temp reading on my heat pump it's 69 degrees,just happens to be around the same as the air temp. Right now. Last I checked was at 1 pm. I read here that it's best to close when water temp is 60 or below.
    Now I know the temp is going to go up n down this time of year but when do you take a shoot n just close. Don't want to sound paranoid but every spring I open to a swamp. Thanks
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Is it too early?
    I don't plan to close until the pool is under 60 for several days or they're predicting a hard freeze. Probably about the time I put the heater in the stock tank.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
