Thread: Can I use different bulbs in a spa light?
    I need to change the bulb on my spa light. It is a pentair light and calls for an r20 bulb. I would like to put in a colored bulb but the three that I have bought are all a centimeter or two longer than the one in there. I would have thought all r20 bulbs were a standard length?? The r20 is a medium width base bulb. Can I take say a different medium width base bulb, say a PAR20, of the the same or lower watts and came volts and replace it with that?
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Can I use different bulbs in a spa light?
    Are all of the bulbs you looked at or tried made for use in a pool or spa?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Quote Originally Posted by ps0303
    I have a spa replacement bulb that is an R20 that fits. I would like to put in a colored bulb except all the colored r20 bulbs are too long. So was wondering from an electrical point of view, can any medium base bulb go into a medium base socket as long as it stays at or under the watt limit? Are spa bulbs special in any way? Btw, I tried the covered caps and they are useless.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Pool/spa bulbs are different than say a regular flood light bulb. As long as the bulb is made for a spa, then you can use it. If it doesn't say "spa" or "pool" on the package, do not attempt to use it. It will overheat and possibly explode.
    Paul
