Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Any good suggestions to remove plaster from return threads?
    aquiapools's Avatar
    May 2011
    San Antonio, TX
    11
    After a recent replaster, I can't screw down the eyelets because of gunite overspray on the threads of the pool returns. Any ideas to get this stuff off? The returns are original to the pool, so they may be too brittle to withstand any attempts to chip it off.
    Jason
    Aquia Pool & Spa
    Proudly serving San Antonio, TX
    22,544
    Re: Any good suggestions to remove plaster from return threa
    Welcome to TFP.
    What material are the fittings made of?
    What size are the fittings?
    Assuming they're 1½" female you could try a pipe tap that size to clean them out.
    aquiapools's Avatar
    May 2011
    San Antonio, TX
    11
    The fittings are plastic and they are 1-1/2 male. The plaster is on the threads of the returncoming from the wall. I can't screw down the eyelet retaining ring.
    Jason
    Aquia Pool & Spa
    Jul 2010
    Philly
    332
    Like Bama said, a properly sized tap would make quick work of it. However a tap that size can be expensive. If you can find a length of threaded pipe that matches up to your fitting it should work as well as a real tap. If the pipe coming from the wall is male, a 1 1/2" coupling will work as a die. Be gentle and go slow, reversing frequently to allow the plaster chips to dislodge from the threads.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Aug 2007
    near the swamp
    806
    muriatic acid
    Qwaxalot's Avatar
    Jun 2012
    439
    I would call the plaster guy and have him come and finish the job.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    22,544
    Muriatic acid might work but it may also streak the wall under the fitting. Return fittings should have female threads not male threads. There are three parts to most return fittings. The retaining ring, the eyeball and the threaded or slip wall fitting that fits into the pipe. Do you have all those parts?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    That is what I was thinking too. It sounds like the threaded inserts are in the returns and can be removed which - if true - solves the problem.
    -sent with Tapatalk 2
    aquiapools's Avatar
    May 2011
    San Antonio, TX
    11
    These are spa jets and what is coming out of the wall has threads on the outside. The retaining ring will not screw down the threads because of the plaster on the threads. I took the retaining rings to a home improvement store and they would not screw down on an 1-1/2 PVC male adapter. The threads looked the same, but I didn't try using a galvanized nipple. I thought of that only after I left the store.
    Jason
    Aquia Pool & Spa
    May 2012
    Montville NJ
    545
    it would be tedious, but what about a dental pick or probe? Just pick it out.
    I would leery of trying to chase threads with a tap (or die) on PVC. It could easily turn into cutting new double threads.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by aquiapools
    Just to be clear - you are SURE that there is no internal part that can be removed that would leave you with the 1.5" MIP threads? I thought my fittings were like that until I did some reading and realized mine had inserts that could be removed. Maybe a picture?
    Mar 2011
    Scottsdale, AZ
    406
    Remove the eyeballs, and use a threaded section of 1 1/2" schedule 80 pipe to clear threads. Just ease in, and ease out and it will clean them right up.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Just-a-PB
    The only threads showing are external like the ones the retaining collar for an eyeball fitting would screw onto.
    - Sent using Tapatalk
    Mar 2011
    Scottsdale, AZ
    406
    Eyeballs are cheap, rip them out and replace.
    aquiapools's Avatar
    May 2011
    San Antonio, TX
    11
    Quote Originally Posted by UnderWaterVanya
    I will shoot a picture tomorrow when I am at the pool.
    Jason
    Aquia Pool & Spa
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I've used a dremel with a tiny grinding tip to clean plaster out of my in-floor cleaner heads...not sure if the pool is drained in your case or if the you could get the tool at the right angle.
    Jun 2012
    Mint Hill, NC
    2,589
    Sounds like a plan!
    aquiapools's Avatar
    May 2011
    San Antonio, TX
    11
    Here is a picture of one of the returns.
    Jason
    Aquia Pool & Spa
    22,544
    Looks like they left the eyeball fitting in the return and plastered around it. Either that or that's a male pipe adapter. Either way it should be female.
  20. Back To Top    #20
    Jun 2012
    Mint Hill, NC
    2,589
    Looking inside that return - is there a slot notched in it? The Hayward one's have a notch cut into them that allows you to insert a plastic card and use it as a wrench to remove the insert. The point Bama is making is that this part you see sticking out is very likely just screwed into the r"eal" return plumbing and this part can and should come out which will allow you to throw it away and get a new one. If you reach into the return with a dental probe or if you could get into the pool and look carefully up in the hole with some light you probably would see a small lip all the way around about 2 inches inside the hole where the insert ends and the actual return pipe is larger than this insert.
    Take a look at this image - I won't post it inline here - but this will help you visualize it:
    http://www.poolpartsonline.com/popup.as ... ze%3dlarge
    Notice the item on the far left? It is what we think the part sticking out of your wall is.
