Results 1 to 7 of 7
Thread: what changes borate levels in a pool?
    Melbourne, Australia
    74
    Is borates simmilar to CYA in terms of how levels drop / increase?
    eg. do you need to drain if borate levels get too high?
    What are the ill effects of too high borate level say 70ppm ???
    Does anything "consume" borates to make the level drop?
    The reason I ask is that CYA was such a problem for me....
    If the borate level is perfect and you are continually adding borax to the water to adjust pH up will that lead to the same or simmilar sort of problems as continually adding and therefore raising CYA does?
    13,000 gallon; sand filter; inground; fibreglass; pump not sure yet (need to check); Installed over 12 months ago.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: what changes borate levels in a pool?
    Same as CYA. 70 ppm is not overly harmful to humans but becomes more harful for animals. If you are constantly adding Borax to adjust PH up, there is something off with your chemistry or you are possibly using Trichlor to chlorinate. If so, in time you will need to reduce CYA levels which will also reduce your borate level.
    74
    Nothing off with my levels, just that pH was a bit low at 7.2 everything else is spot on.
    More curious than anything else...
    My CYA is at 40 and I will only be using liquid chlorine from now on. I've got enough trichlor pucks / powder etc. in the pool shed to serve purposes of raising CYA if I need to....
    No more pool shops for me!
    What I am really keen on is understanding the maths behind the pool calculator and some of chem geeks calculations but I am not too good with non metric calculations!!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Quote Originally Posted by juzzie
    Sorry about that...I misread your question above, thinking your PH is continually climbing. If not, the amount of borax added to adjust PH during the course of a year is negligable at best. The borate strips I believe are at best +/-10 ppm accuracy anyhow.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,763
    Juzzie, just soyou know, while some don't like the app because it doesn't remember your setup, there is an iPhone/iPad app based on the pool calculator that does convert to metric. If you have an iPad or iPhone, you can check it out in the app store.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Smykowski's Avatar
    Sep 2011
    3,065
    Upper right hand corner of the pool calculator (web version) there's a drop down menu: you can set it to US, metric, or imperial.
    74
    Thanks guys, I have been using the pool calculator in metric and it works fantastic!
    Just curious about some of the calculations that's all (I was one of those kids who had to pull things apart just to see how they work!!!)
