Thread: Intex Take down: how to winterize pentair pump, cart, HEATER
    Hi all,
    I am ready to drain and take down my Intex Ultra, but this year for the first year I have Pentair equip, instead of Intex. I am hoping someone can walk me thru what I do to take all this down. The plan is to unhook everything and store the pump and filter in the garage and if I can, even take the heater in. (hvac neighbor will help with the gas connections, i'm worried about water in this topic).
    My primary question right now is, What do I need to do with the equipment BEFORE I drain the pool? Do i need to do something now (before I drain the pool) to Pump or blow out, or otherwise remove residual water in any of the three Pentair pieces? Or do I just drain the pool, disconnect all the flex pipe, and dump any extra water from the Flex pipe, pump, filter, heater? I just need to be sure I don't incorrectly store any of this with water that can do damage, but, especially with the heater, I'm not sure how to ensure the water is all out (or how much if any sits in it when it is off) and want to be sure I don't prematurely drain the pool if I need a working pump to winterize the heater.
    Thanks!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Re: Intex Take down: how to winterize pentair pump, cart, HE
    So, for others with a similar question, I took off all the plumbing and opened all the drains on the heater. Then, with the help of Pentair tech support, used an air compressor (not more than 5 psi) to blow out the coil - they had me remove the pressure switch and blow from that hole. They say I am done and should be fine. Hoping next spring everything works a-okay.
