Thread: Newbie - bottom drain and skimmer
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    132
    What are the advantages/disadvantages of piping the bottom drain to a skimmer?
    Why not just pipe the bottom drain straight back to the pad?
    If you have two bottom drains, do both get piped back to the same skimmer, or should they each go to a separate skimmer?
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Newbie - bottom drain and skimmer
    There are no advantages to the pool owner, but several disadvantages. It saves a little pipe for the installer.
    Plumb everything back to the pump for the most flexibility.
