Results 1 to 19 of 19
Thread: Chlorine level for IG pool in Canada
    XRAYTIM's Avatar
    May 2009
    St.Catharines, Ontario, Canada
    12
    Hi Everyone
    My question: What are your thoughts for the maximum chlorine-ppm to use when closing your pool with a vinyl mesh cover?
    My wife came home from the local pool store with 30 litres (7.9 gallons) of 12.5% liquid chlorine for the final pool closing shock because thats what the pool-store recommended.
    Using the http://www.poolcalculator.com I calculate that the chlorine level will increase by 63ppm! So the pool company is suggesting the chlorine level be about 68 ppm before I cover the pool?
    Our pool is:
    60000 litres (15850 gallons) 14'x28' in-ground vinyl we are in southern ontario canada.
    chlorine sanitized by 3" pucks/feeder and granulated chlorine
    safety-mesh cover for the winter
    pool water is balanced as per TFP recommendations
    Thank you for your recommendations!
    61000 liter(16110 gallon) Inground, Vinyl liner, 21" Sand filter, 3/4hp pump, 12% liquid Chlorine sanitizer, TF-100 test Kit
    38,475
    Re: Chlorine level for IG pool in Canada
    Welcome to TFP!
    what is your CYA level? I think the general idea is to raise to the shock level of FC, but that depends on the CYA. I will say that their recommendation is likely way too high.
    How does the water look now?
    Posted from my Droid with Tapatalk ... sorry if my response is short
    XRAYTIM's Avatar
    May 2009
    12
    Hi
    Thanks for the fast reply
    cya is 40 & water is clear (free chlorine 5 ph 7.6 ta 140 ch 280 temp 60 degrees) So in the summer I would shock at 16-20 ppm.
    Does everyone agree that raising the chlorine to 68ppm would be way too much?
    Anyone have any thoughts on what the maximum chlorine ppm should be for winter closing? (vinyl and mesh cover)
    No sense sweating the cost of chlorine because the chlorine is sitting in my garage now anyways.
    Will the high chlorine damage the vinyl liner?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by XRAYTIM
    Per this: pool-school/closing_in_ground_pool
    The answer is standard shock level. However I'm not sure what a "vinyl mesh cover" is. Is this cover like a leaf cover - allowing sunlight to reach the water? Or is this more like a standard safety cover - opaque?
    XRAYTIM's Avatar
    May 2009
    12
    Quote Originally Posted by UnderWaterVanya
    Anyone have any thoughts on what the maximum chlorine ppm should be for winter closing? (vinyl and mesh cover) [*]corrected (vinyl liner and mesh pool cover)[*]
    UnderWaterVanya thank you for the link. Sorry "vinyl and mesh cover" should have been "vinyl liner and safety mesh pool cover"
    Ok, I am sticking with the TFP forum recommendation and I will raise my chlorine level to at least 20ppm.
    What is niggling at me is What is the downside to pouring in the extra chlorine? Would you expect it to damage the liner?
    38,475
    Yes. Elevated FC levels can fade the liner. Although you would have to go above mustard shock level for extended periods of time ... Certainly still no where near as high as the store suggested.
    XRAYTIM's Avatar
    May 2009
    12
    Re: Chlorine level for IG pool closing in Canada
    Thank you jblizzle & UnderWaterVanya for taking the time to help me sort this out.
    Jun 2012
    Mint Hill, NC
    2,589
    Welcome!
    As mentioned, the mustard algae shock is as high as is recommended. If the water is 60 degrees Fahrenheit or lower the standard shock level should be sufficient.
    -sent with Tapatalk 2
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Was curious, since you said you are using pucks in a feeder and granulated chlorine, how you measured your CYA?
    XRAYTIM's Avatar
    May 2009
    12
    Quote Originally Posted by PAGirl
    Local pool store gives me a CYA level
    Pucks are used for maintaining sanatizer, and granules are used for shocking pool, opening pool, and algie if needed.
    38,475
    Well ....... continued use of puck and and granules adds FC and CYA continuously. FC is consumed CYA sticks around until it is too high and you pool turns green. I highly recommend you read through Pool School a few times this winter. Then order yourself a test kit, switch to liquid chlorine and don't believe what the pool stores tell you.
    Pool Stores are notoriously inaccurate and non-repeatable when testing ... and CYA is one of them they are the worst with. Get a kit and trust yourself.
    Now, I will say, since you are up north and likely replace a lot of water over the winter, using the pucks might work for you. The winter drain lowers your CYA. But, you need to KNOW your levels and understand what everything you put in the pool affects. That way you ensure your never go green.
    Jun 2012
    Mint Hill, NC
    2,589
    What type of granular chlorine? Dichlor is common and adds CYA. Trichlor has CYA also but is rarer to see used in powder form. Lastly Calhypo is frequently used and dies not contain CYA but does increase Calcium Hardness.
    - Sent using Tapatalk
    XRAYTIM's Avatar
    May 2009
    12
    Calcium hypochlorite 65% granules & Trichloro-s-triazinetrione 3"pucks
    I would love a tfp pool test kit .... But its not available in Canada I priced a similar Taylor kit locally and got sticker shock$. Well north of $100
    I use a Taylor k-1004 kit at home. $40 if memory serves.
    • dpd reagent 1 r-0001
      Dpd reagent 2 r-0002
      Dpd reagent 3 r-0003
      Ph indicator r-0014
      Thiosulfate n/10 r-0007
      Acid demand r-0015
    Anyhow hardness does climb through the season (June-aug) ending just over the recommended range. I close the pool in late sept. Then sept to until the mid-may-open rain adds about 2900 (guess) gallons (14'x28'x1' rain + snow thru mesh safety cover) This dilution usually puts hardness to just below the recommended range.
    I will review the pool school.
    Just need to figure out away to get the tfp test kit despite being in Canada.
    38,475
    Unfortuneately, Dave can not ship the TF-100 out of the US due to his agreement with Taylor. The K-2006 kit is the same thing, just different quantities of reagent.
    This is where you can order the K2006, but you are right, they have quite the markup in Canada:
    You can get the Taylor kit from here:
    http://piscines-apollo.com/cubecart/tes ... -2006.html
    Your terminology may not quite be correct, or I misunderstand. Hardness is not the same as CYA.
    The cal-hypo will add CH
    The trichlor will add CYA ... this is really the one you need to worry most about getting too high as it will result in a green pool when the FC is too low.
    Read up and ask any questions. I think maybe the thing you are missing is that if you maintain the correct FC for your CYA level, then you should never need to use cal-hypo to "shock" the pool on a schedule (if that is what you are currently doing).
    XRAYTIM's Avatar
    May 2009
    12
    Re: Chlorine level for IG pool in Canada cya. Hardness....
    This thread is jumping around a bit......
    I useCal-hypo for shock every two weeks. I've never been able to go longer or else I will get Algae. Someone suggested it could drive up hardness so I commented on my experience.
    Trichlor does add chlorine and cya. But the pool company tests for cya. I've been cautioned about their accurracy. I will find a source for Dave's or the Taylor kit without paying 2x the price my neighbours 20min south pay
    How many weeks can you go without shocking? In my case it's a small warm pool with 25-75% tree shade throughout the day.
    I will make getting the kit a priority.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If you add a calculated amount of chlorine daily, you will not need to add bags of "shock". Around here, shocking is a process of eliminating algae when levels of chlorine fall below the recommended amounts for your CYA level. That's why it's important to have an accurate reading of CYA. If you read pool school it will make much more sense than it probably does right now!
    Jun 2012
    Mint Hill, NC
    2,589
    Holding the recommended FC levels after first using the Shock Process to get rid of any living algae will keep the algae away without any need for routine regular shocking. Routine shocking using "shock" from the pool store is akin to paying for a service by sending them a random but higher than likely needed number of dollars every few weeks. This may work for many but if the amount is not quite enough - you still get hit with the late fees - and if the amount is too much - you're wasting money and sowing confusion.
    Make friends with a Pool owning BBB yank south of the border and make a road trip. Have them order an extra kit for teaching purposes and go study with them. Then take your homework supplies back with you and send regular reports so you can be graded <wink>.
    Unless I make a mistake like when I failed to ensure that my in-laws had bleach for a couple of days - I never need to shock.
    XRAYTIM's Avatar
    May 2009
    12
    Pagirl, Underwatervana, & jblizzle You folks are great! Great analogies, pointers and suggestions. Thank you for helping me sort all this out.
    Never needing routine shock would be ideal! I am looking forward next season.
    Hi, I also live in Southern Ontario, but have an above ground pool. When I close my pool I raise the chlorine levels with liquid chlorine, about 6 L of 6% per ~20,000 L of water. During the year I have added CA and copper based algaecide as well and more recently, since my water is alkaline, muriatic acid. During the year I add liquid chlorine and muriatic acid using an automated system. On closing, the pH of my water is 7.0 - 7.2 and total chlorine is about 5 - 10 ppm. I put a light and water proof cover over the pool after mixing the chemicals thoroughly via my automated system prior to returning them to the pool. On opening the pool, my water and liner are perfect, looks the same as when I closed it; the reason is the light and water proof cover which extends the life of the pool chemicals and keeps dust and other dirt out of the pool; my last vinyl liner lasted 13 years!. With an above ground pool, it is easier to manage the type of cover I have, I just siphon off the water on the cover in the spring and remove any large debris manually. With an in-ground pool, it will be a little more work to get the water off the cover, but the pay-off will be clean water in the spring without having to put a ton of chemicals in the pool. I would highly recommend a water and light-proof cover for your pool.
    15-foot above ground pool, Hayward Turbo-Flow pump with sand filter, use liquid chlorine, Metchlor Caddy pool chlorinator; Metchlor Caddy also used for automatically adding muriatic acid; winterize with light and water resistant cover.
