Thread: First time closing SWG pool
    Aug 2011
    Clarks Summit,Pa.
    37
    I have closed my pool for seven years using winterizing kit from in the swim,it worked well,
    as far as the chemicals go ,after i bring the pool up to shock and all of the and all of the other test levels are ok ,do i add algecide and will that be enough or should i get a winterizing kit
    12,000 gal. 14x28 Inground vinyl liner (2004), 1 HP. Jacuzzi magnum pump,
    Raypak heater, Jacuzzi laser sand filter,Autopilot DIG-220 SWG, 35/22 cell,
    TF-100 test kit,K-1766 saltwater test kit, speedstir
    38,285
    Re: First time closing SWG pool
    Assuming you are not going to be running the pump and generating chlorine ... a SWG pool is not different than any other pool you are closing.
    Personally I have never closed a pool, so will defer to others ... only extra thing to do might be to remove the SWG cell to store indoors.
    Aug 2011
    Clarks Summit,Pa.
    37
    Jason thank you,everything but the sand filter and heater i remove and store inside,they are drained and plugs installed
