Thread: broken pump and rain = GREEN!
    Purchased the TF-100 kit about 5 weeks ago and the pool has been great! Thanks again for this forum.
    Last week, my pool pump stopped working and we had lots of rain. The pump is back to working order but the pool is now green. I've completely scrubbed and vacuumed the entire pool. I've also changed the filter. My water tests are as follows:
    pH: 7
    FC: 15 ppm
    CC: .5ppm
    TC: 16 ppm
    TA: 50
    CH: 70
    CYA: 80
    Should I do a partial drain to lower the FC? I'm using ultra bleach as my daily chlorine.
    Thanks.
    Chad
    Chad
    Summer Escapes 15' x 42" Quick-Set Ring Swimming Pool installed June 2012
    3200 gallons, cartridge Filter, Above ground, vinyl
    Filter Pump RP800 780 G.P.H.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: broken pump and rain = GREEN!
    Why would you wish to lower your FC? given you have spent some time on the forum, you will be aware that you need to perform the shock process and pass the OCLT.
    Your shock level with CYA at 80 is 30ppm FC, I don't know if you already have been shocking with the FC up at 15, but you have to go higher on FC, not lower,
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    Mar 2010
    Spring, TX
    1,082
    He may have meant to do a partial drain to lower CYA and not FC. Hopefully it was just a typo on his part.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Jul 2012
    296
    Ah, for some reason I read the post and thought it was an SWG pool, in which case shock level is 31 and CYA is on the high side and could be lowered.
    Stuart Murray
    Scotland UK
    UK NPPOC
    Yes. I meant to say lower CYA. I was concerned that my CYA reading was higher than 80 as the green color is strong and the test is pretty subjective.
    I decided to do a partial drain/refill(it's a small pool). I'm shocking to 31ppm and will run a OCLT in a couple of days. I'm open to additional suggestions.
    Thanks.
    Chad
    Chad
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by chadlife
    Your plan seems reasonable.
    -sent with Tapatalk 2
