Thread: Order of chemicals/ready to close
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    We have cleaned out the pool. Ladder out. Skimmer plate is on.
    All that's left is taking it to shock level and circulating that through the pump, then covering (also disconnecting pump & hoses, etc.).
    Here are today's chemistry numbers (obviously pre-shock)
    FC: 4
    CC: 0
    Ph: 7.7
    TA: 60
    CYA:45
    My question is on Ph & TA. Should I add some Ph-minus (Ph has always crept up all summer), and if so, should that happen before shocking?
    Same question for TA. Should I add baking soda to raise it, and if so, what order and how much interval between?
    Thanks.
    Pool: 27' x 52" AG, about 16,500K, cartridge filter
    Waterway 175 sq ft 1.5 hp pump 2-speed
    Deck first of June!
    30,419
    Re: Order of chemicals/ready to close
    Not mandatory, but I would lower pH to 7.2 just to get some "cushion" as it tends to rise anyway.
    (For semantics sake, you are not shocking the pool but simply raising the FC to shock value. Shocking the pool is a process as described in pool school. )
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    Re: shocking, that's true. Thank goodness I've never had to shock the pool all summer
    You think the TA is ok to leave at 60? I'll deal with the Ph first, then how long before I can add the bleach?
    Deck first of June!
    30,419
    A somewhat low TA won't really hurt.....raise it some if you like....I wouldn't.
    You can add chlorine immediately once you adjust your pH.
