Thread: First cleaning of filter cartridges
    Apr 2012
    Newton, NC
    173
    Our pool project is moving a bit slowly due to the sloped area where it had to be located. They built up an elevated section where the spa is located and they are now building a retaining wall up-slope from the spa. So, the pool has been in the ground and operational for a few weeks. The heavy rains last Monday and Tuesday created a lot of mud puddles around the pool which splattered into the pool. So, Wednesday morning we had a "chocolate" pool.
    The pool had already been vacuumed a couple of times ovewr the past couple of weeks to clean out dirt, mortar, etc. I vacuumed the pool once to get a lot of dirt that had settled on the bottom. This afternoon I tried vacuuming again, but I was not getting good suction. With the multiple vacuumings of the pool, I figured that maybe the cartridges were getting dirty. I had not seen any increase in pressure, though.
    What a sight when I opened up the filter. All 4 cartridges were absolutely caked with crud. I'm surprised any water was making it back to the returns. So, I cleaned all 4 cartridges (used the Aqua-Comb that I had bought.....works real well ).
    I got the cartridges back in the filter, cleaned all the gaskets, and fired the pump back up. It was starting to get dark, so I'm hoping tomorrow morning the pool will start looking like a pool instead of a swamp.
    I did check the pH and Chlorine today. I was very happy that the pH was 7.5, the FC was 7 (I had boosted the SWCG since I was concerned about all that crud in the pool), and the CC was zero. Not bad for a horrible looking pool.
    The retaining wall will be done on Monday, and they should be pouring the decking on Thursday or Friday. That should keep the pool mud-free.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Re: First cleaning of filter cartridges
    Glad to hear it, sounds like the filters are doing their job.
    You mentioned the pressure hadn't gone up from I assume your recorded startup pressure when new?
    Did the pressure drop since you cleaned it?
    Does the pressure gauge go to zero when you shut the pump off and come back up to a number consistently once you start the pump?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Not sure if this applies... but I'll throw this out there. When you check your pressure gauge on your filter, make sure your pump is not on "low speed." I was wondering why my pressure never ever went up... and I've got a new pool with plaster dust. I read about the VS pump on this forum (jbizzle I think) and sure enough, the gauge jumped 8psi. Just a thought.. Good luck!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Vince, if you want to prolong the life of those cartridges, vacuum to waste when you have alot of crud on the bottom of the pool. This way it doesn't dirty up the cartridges.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
    Apr 2012
    Newton, NC
    173
    I had read the post about checking the filter pressure when running at a higher speed. During the Ecostar's 3 minute prime, my filter pressure was consistently right at 10 psi. When it slowed down to normal operating speed (I normally run at 1,553 rpm), it consistently dropped to about 2.5 psi. Since cleaning all the cartridges, I am still getting those same readings.
    And, y_not, yes it did and still does drop to zero when the pump is off.
    Today, I was having trouble getting the pump to prime. When I shut the pump off, I heard a lot of gurgling. Since the problem just started after I cleaned the cartridges, I was quite confident I had made a mistake putting the filter back together. Sure enough, I felt the side of the filter under the drain plug, and it was wet. There was no puddle on the pad, it was just darkened from being damp. A 3/4 additional turn on the plug, and the gurgling stopped.
    No more priming problem. It sure doesn't take much of a leak to cause problems.
    tpcorr, I'm not sure how I would "vacuum to waste." I don't have a way to direct water coming out of the pump anywhere except into the filter. They are going to be installing an additional 3-port valve between the pump and filter to allow me to drain water from the pool, if needed. Would that be vacuuming to waste? Seems like I would be sucking a lot of water out of the pool.
    The good news about the cartridges is that the PB warned me that the cartridges would be getting very dirty during the installation. He recommended I get a cheap set of generic cartridges. So, I got some Unicell cartridges on-line and put the new Hayward cartridges in a box. If the Unicell cartridges don't last very long, I won't be too upset.
    Vince L
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by VinceL
    Yes.
    -sent with Tapatalk 2
