Thread: Ok to drain this chem mix into plants?
    bobhatfield's Avatar
    Phoenix, Arizona USA
    27
    Need to drain 20% of my pool. Ok to water plants with this? In dry Phoenix where plants could use.
    TF-100 test kit:
    FC 0.5
    CC 0
    TC 0.5
    TA 170
    CH 800
    CYA 100+
    K-1000 basic test kit:
    pH 7.8
    30K Gallons | Cartridge | In Ground | Plaster | WhisperFlo 2HP | Filter Flow Rate: 150 GPM
    SWG installed - but not working, needs new cell
    27
    Re: Ok to drain this chem mix into plants?
    Google search led me back to tfp for some answers on "normal" pool water and plants:
    safe-to-backwash-into-the-lawn-t6740.html
    Mar 2007
    San Rafael, CA USA
    12,082
    Lawns can tolerate more than some plants. It's mostly the salt level (sodium chloride) that is an issue (and boron can be an issue, but it sounds like you don't have borates in your pool water). You have high calcium so probably have high chloride as well. Probably not as high as a salt pool. Probably OK for lawns and sturdier plants, but delicate plants might not like it and you should water them with your regular sprinkling system to dilute the pool water, if you end up using that.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I'd use it on my lawn without any hesitation. I don't know about anything else.
