Results 1 to 10 of 10
Thread: How to drain a cartridge filter pool?
    bobhatfield's Avatar
    Phoenix, Arizona USA
    27
    I need to drain about 20% of my pool and refill with tap water to lower CYA. However, it's a closed system with a cartridge filter - no backwash tap. Do I just rig something up such as remove the swg cell and redirect the flow via a backwash hose? I can restrict intake to just the drain with valves. Or is there a better way?
    30K Gallons | Cartridge | In Ground | Plaster | WhisperFlo 2HP | Filter Flow Rate: 150 GPM
    SWG installed - but not working, needs new cell
    Feb 2008
    Denton, TX
    5,061
    Re: How to drain a cartridge filter pool?
    You may just head up to Home Depot and get yourself a cheapish sump pump and use that. You can rent one, but I am willing to bet that you will need it again at some point. Might as well have your own.
    27
    Quote Originally Posted by 257WbyMag
    I don't know, it's mostly bone dry here in Phoenix.
    phipsi1237's Avatar
    Jan 2011
    North Las Vegas, NV
    228
    I think it costs about $30, maybe less,to rent a pump for 4 hours. Should take about 2 hours to drain 6K gallons once it's running.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    27
    Actually, may not be a bad idea because one could calculate gallons per min instead of eyeballing water level...
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    This may help it's what I did with mine:
    adding-a-to-waste-drain-to-plumbing-t35088.html?hilit=drain
    Hope it helps.
    kkendall's Avatar
    Phoenix
    64
    My PB actually put a hose connection between the pump and filter. There is also a drain plug on the bottom of the filter canister (below the pipe connections). But the pump suggestion would be the way to go if you don't have a hose connection.
    * 18.5 K Gallon, 8ft deep, IG, Pebble Radiance * Pentair VS 3050 Pump w/420 Cartridge Filter
    * Blue Square Q-360 In-floor Cleaning System * UltraPure UPP25 Ozone Generator
    * Pool startup: 09-04-2012 * TF-100 Test Kit
    Mar 2011
    Scottsdale, AZ
    406
    We always install a hose bib on the return side of the filter to make it easy to drain down some water if needed.
    You could cut one in. Not a bad thing to have when we get a big storm and pool is overflowing.
    27
    Great ideas, I only wish I'd waited to read these before heading to Home Depot. I removed the swg and added this 3" to 1.5" rubber fitting with a piece of PVC to clamp the hose to. It worked great but would rather have the drain plug valve!
    [attachment=0:213rvfzm]image.jpg[/attachment:213rvfzm]
    Mar 2011
    Scottsdale, AZ
    406
    That is some nice out of the box thinking.
    And when you are done you can return it all.
