Thread: Opinion on latest test results please
    Jun 2012
    Lafayette, Ca / USA
    260
    OK, after 3 months of testing & adjusting, this is where I am - and I could use some opinions as to whether there is anything you would do to the water:
    From the TFT-100 :
    FC = 8.0 (yea, a bit high for my CYA .. for the last 5 days I was using the Blue test kit vs the FAS/DAP test .. So given the yellowish color (suggesting 5.0), I was adding 36-42 oz of bleach almost nightly ... I'll let it go tonight & possibly tomorrow. That Blue kit is SOOOO subjective).
    CC = 0
    PH = 7.5
    TA = 110
    CYA = 50 (again, Soooo subjective .. could be anywhere between 40 & 60 to my eyes)
    CH = 260
    Pool Temp = 82
    I think the water could be a bit more "sparkly" or clearer, if that makes sense. I mean, everyone says how great it looks, and I mostly agree - but more clear would be a side benefit to ME personally. Is there anything I could do to get it just a bit more CLEAR? or maybe I should just give up for this season - probably only another 3 weeks of use anyway.
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Opinion on latest test results please
    You have reached a very good chemical level, and I would only look to keep everything where it is. Don't worry about the FC level either it certainly won't do any harm at 8ppm, especially in a residential pool, it gives you some room to maneuver on your maintenance regime.
    If you are looking for a further sparkle to your water you might want to look into adding borates next year, as users report a more silky shine and feel to the water. If you are going down the borates route you will likely have to bring your TA level down to between 70-90
    Well done on your numbers beer time
    Stuart Murray
    Scotland UK
    UK NPPOC
    Butterfly's Avatar
    South Carolina
    10,045
    One of the first signs that something is trying to get started in your water is a dull/flat appearance of the water, iow, it loses its sparkle.
    If it was my pool, I'd bring it to shock level tonight and do an OCLT tonight/tomorrow morn.
    If caught early enough, a nascent algae bloom can be nipped in the bud
    You're done SLAMing when:
    Smykowski's Avatar
    Sep 2011
    3,065
    Numbers look good. If your FC consumption has been pretty constant, the dullness could be nonorganic debris clouding it up. I'd try giving it a good brush and vacuum, then increase the pump run time for a day or two.
