Thread: Just set up AGP Hook up pump or just cover?
    May 2012
    Des Moines, Iowa
    14
    I know it's crazy but we just got our AGP set up & filled. I have not yet hooked up the pump. I had to do it now as our deck is being built around the pool. It's 41 this morning, the water is frigid. It's 25x13 rectangular by Splash & I live in Iowa. Should I get the chemistry right & hook up the filter or just lower it, seal it up, & begin in the spring? I don't expect it will get warm enough to use this year. I believe I need to bring the chemicals to closing levels, but don't know if the filter/pump needs to be hooked up to circulate everything or can I just stir/agitate it enough without the pump?
    13x25.5 Splash Titan3 AGP
    9800 Gallons Sand Filter
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Just set up AGP Hook up pump or just cover?
    Have you read the article in pool school?
    pool-school/winterizing%20and%20closing%20your%20above%20group%20pool
    I don't know if you should balance first (CH/TA/CYA), someone else with experience of seasonal pools will help but I would certainly get pH correct and follow the procedure detailed in the howto above including chlorination.
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
