Thread: Jalpeno Barbecue Burgers
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Here's a recipe I'm working on. I stole the original fromHere
    Jalapeno Barbecue Burgers
    * 4 roasted seeded jalapeño peppers, coarsely chopped
    * 2 pounds ground chuck
    * 2 tablespoons garlic powder
    * 2 tablespoons marinated onion, chopped. I use ranch dressing mix and olive oil for the marinade
    * 1 tablespoon ground cumin
    * 1 tablespoon chili powder
    * 1 egg
    * 1/2 cup Italian seasoned bread crumbs
    * 1/2 cup Cattleman's Original barbecue sauce (I'm tempted to try some Carolina style sauce)
    * Salt and pepper to taste.
    * Memphis style dry rub
    Combine all of the ingredients except the rub and mix well. You want it much runnier than you'd think. I usually have to give it another shot of barbecue sauce to get it like I want. Here's the key step: Form the meat mixture into a loose blob that is roughly shaped like a patty. Squeezing, squashing or any serious shaping are to be avoided. I like to place the "burger blobs" on a platter and chill in the refrigerator for an hour before grilling if I have the time. It helps the blobs stay together when you put them on the grill. Dust both sides with the rub as you place them on the platter. You'll still probably need to use a spatula to transfer them from the platter to the grill.
    Put the burgers on a hot grill. Don't try to turn them too quickly or you'll tear them up.
    I like to top the burgers with grilled thick sliced Vidalia onions, marinated and basted with olive oil and ranch or Italian dressing mix. Put a skewer through the onion to hold it together. It will take longer to grill the onions than the burgers, so plan accordingly.
    Serve the burgers and onions on a toasted bun.
    Still making some tweaks.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Sounds good, and maybe a little messy.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Guest
    John, come on over any day and make them! They sound really good. I'll supply the beer!
    SW Indiana
    9,198
    Quote Originally Posted by waterbear
    If you weren't so far away...
    I still think it needs more tweaking, and I'm considering adding some sugar or trying a different sauce. Cattlemen's is my favorite, so I always have some.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    You had me at Jalapeno.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
