Thread: water test results
    Jun 2012
    SW Pennsylvania
    77
    water test results
    Ok, I got my TFT 1000 yesterday and got the following result
    FC 3
    CC. 5
    TC 3.5
    TA 500
    CH 110
    CYA 20
    PH. 7.2
    Questions are do I need to amend the water or is it safe to cover and close? Temp is 68 degrees thanks for helping- Melinda
    AG AquaLeader 21x43 Oval 54" deep. Hayward 2speed 2HP pump,Hayward 350,000 BTU NG Heater, Cartridge filter. Since August 2012. TFT 100 test kit
    22,553
    Re: water test results
    I hope you have the CH and TA numbers switched or that the TA is wrong.
    If the TA is correct I'd try to get that down a good bit before you close.
    The only other thing I'd do is raise the FC to 10 ppm right before covering it.
    Jun 2012
    SW Pennsylvania
    77
    Thanks Dave, I retested and it was bad math. TA is 50. So I will bring FC up to shock level according to CYA leve and let circulate for a couple hours and close.
    22,553
