Results 1 to 16 of 16
Thread: is this stuff CYA? and how much will my CYA go up?
    U.S.A. - California
    32
    so, I went to my local pool store and they told me to just pour all this on my pool and this would bring my CYA level. I know you cannot lower CYA by any other way except by draining your pool. So my question is: Would this bring my CYA to 100 ?
    [attachment=0:krjc88wo]photo.jpeg[/attachment:krjc88wo]
    The info about my pool is on my signature
    Pool: 5725 gallons
    Filter: SandPro 50 half horse power
    Type Pool: Above Ground Summer Scape
    Made out off: I dont know what type of material is made out off.
    Size pump and flow rate: Half horse power / I dont know the flow rate
    Date of pool intall: June 20th, 2012
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: is this stuff CYA? and how much will my CYA go up?
    It's 68% CYA. So one pound of it will raise CYA in your pool by about 14 ppm. The Na2CO3 will just about cancel out the pH change, which is probably why it's in there.
    PS. Why do you want to get it to 100?
    If you have no CYA in the pool, add a couple pounds of this stuff to get close to 30, and enjoy the convenience of using trichlor pucks as long as you can.
    U.S.A. - California
    32
    Quote Originally Posted by Richard320
    I am sorry I dont understand you question.. is that a good thing or a bad thing?
    Pool: 5725 gallons
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by denisrenepl
    [youtube:14l97och]V2f-MZ2HRHQ[/youtube:14l97och]
    U.S.A. - California
    32
    so... yes or no? O_o?
    Pool: 5725 gallons
    Richard320's Avatar
    Jan 2010
    18,967
    I answered you. That package by itself will raise the CYA level in your pool by 14 ppm.
    How high that will be depends entirely on what the level is now.
    pool-school/read_before_you_post
    Asking for Help
    When starting a thread asking for help with a specific issue please include the following in your initial post:
    Test Results! Test Results! Test Results!
    There is nothing more important than current valid test results. Here's what we need.
    FC - Free Chlorine
    CC - Combined Chlorine
    pH -
    TA - Total Alkalinity
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer)
    Borates - (if you are using borates)
    Only the better kits have all of these tests, please read this article to understand why we need this information, and this one to see some test kit options. If you don't have a test kit with all of those tests, many pool stores offer water testing.
    If you cannot post these results - do not ignore that fact. Tell us you cannot post test numbers. If you can post only some, tell us you cannot post the others or we'll ask if you forgot.
    Nothing will help us solve your water chemistry issues quicker than current test results.
    U.S.A. - California
    32
    sorry. I dont have a testing kit.
    Pool: 5725 gallons
    38,237
    I suggest you start reading through Pool School a few times, order a test kit, and learn to use the poolcalculator. You will soon be able to actually maintain your pool correctly.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    U.S.A. - California
    32
    last time I check (by bringing a sample of water to the store) the cya was 0
    ... I am sorry, I read those manuals that you guys have (pool school and so on) but they got me even more confused. I wish it was just like: put a cup of chlorine every day or something like. I hate that stupid pool, is not even mine, I just have to keep clean
    Pool: 5725 gallons
    38,237
    With a little reading and learning (and asking questions when needed), and using a good test kit ... the maintenance does almost become: Add X amount of chlorine every 1 or 2 days.
    But, we can not give advice without knowing what you are starting with. And as countless threads on the forum will show, pool store testing is notoriously inaccurate and non-repeatable.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    What Richard is trying to tell you but won't actually tell you is that, yes you need CYA in your pool, but you don't need it to a level of 100. Raise it to 30 or 40. To do this you first need to know how much CYA is in your pool now. That requires a test which you have already had done at a pool store. That's all you have to go by now, but pool store readings are notoriously unreliable. If you have only used bleach in this pool, then it probably is zero. But if you have used pucks, then it isn't zero. What they are also telling you is that a good test kit is a must. You HAVE to have a good test kit to know what the levels are in your pool. Until then, everything is a guess. Order a test kit, and while you're waiting for it to arrive, read pool school. Then after you've read pool school, read it again. It becomes clearer the more you read. Trust me. I've been there.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Apr 2012
    SW Ohio
    456
    Excellent advice
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    In other words to know where you are going you first have to know where your at.....and after you read pool school a few times it will all start to make sense.....everytime i read it i learn something new. Once the water is in balance that is all there is to it just add bleach daily and test fc cc ph its that simple......Mike
    U.S.A. - California
    32
    I get it now! Thanks GreatCanadian!! and thanks for not giving sarcasm.
    Since is not my pool, I have to convince my mom to get a test kit, and also to convince her that POOLS NEED CHLORINE ALMOST EVERYDAY no just when they are green ..
    Thanks!
    Pool: 5725 gallons
    Jul 2011
    844
    Also, get the TF-100 test kit if possible. Get it from duraleigh on this site (go to http://www.tftestkits.net). He'll ship it very quickly and I bet within a month you'll have a whole new outlook on pool maintenance. Good luck!!
    And tell your Mom that she won't be long getting her money back from the test kit because she can stay out of the pool stores forevermore. I get all my chemicals at the grocery store and the hardware store! I didn't step inside a pool store this summer!
    Edit to add:
    Looking at your signature:
    Flow rate of your pump is 2500 gph
    Your pool material is vinyl
    Bestway SWG
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    If for some reason she won't go for the best test kits, read up on the HTH 6-way and seasonal pools. If you can stay on top of the pool and not get an algae outbreak you can maintain your size pool with the HTH 6-way. If you do get an outbreak then you need the better test kit or dump the water, scrub and restart. http://www.troublefreepool.com/pool-...ary_pool_guide
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
