Thread: Winterizing and the filter
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I have a 24" filter with 350lbs of sand in it. I can't move it at all. Not even without water. When I winterize, can I just take off the valve, open the drain valve and cover the opening? I really don't want to move that. I might end up on CNN.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    38,285
    Re: Winterizing and the filter
    I think many people just drain the water and leave it sit. The concern is water freezing, expanding, and breaking something. No water ... no worry.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I was hoping to hear that. We freeze so little down here I am going to leave it. I will zip tie a heavy layer of tarp material over the opening. I actually have a heavy thermal blanket that might cover the whole thing. I guess I could fill it with vodka.
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Glock,
    I have the same sized sand filer and live in Michigan. I don't even remove the muliport valve when I winterize. All I do is remove the drain cap, no blanket. Never had a freezing problem. Save the vodka, if I'm ever down that way, I'll help you drink it!
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Quote Originally Posted by nedchavez
    Glock,
    LOL!! It's a deal!
    I really don't want to remove the top valve but I read so many post here of people checking their spider gaskets so I assumed it had to be done. If leaving it is cool then I will do that.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by Glock
    I never remove mine. Just drain the water, put the valve to winterize and you'll be good.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
