Thread: Simple, manual vacuum (non-robot) suggestions
    Seems like most of the threads cover the robotic cleaners but since I need to watch my spending after a recent house (and hence pool) purchase, I would like to start more cheaply with something I just push around (and maybe just hook up to the skimmer?).
    Any recommendations for a fiberglass pool of medium size?
    P.S. I view cleaning my pool as part of my workout routine so I am not afraid of something that might require a little muscle
    Est 18,000 gallons (30' L x 14-16' W (Kidney shape) x 9' deep-end)/Filter: Sand? (will confirm)/IG/Fiberglass Anthony "vintage" pool from the late 50's.../size pump and the size (flow rate) of your filter: To be confirmed/Est 1958....?
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Simple, manual vacuum (non-robot) suggestions
    Just a simple vacuum hose, skimmer plate, extending pole and vacuum head are all you need. Although I have a fiberglass pool, I prefer the vacuum head that is listed in the link here as a cement pool head. I also have a Wall Whale brand brush.
    http://www.royalswimmingpools.com/maint ... ipment.htm
    Thanks!
    I am having trouble finding the skimmer plate (old Anthony pool with a square housing). Can I just plug the hose directly into the suction whole in the skimmer?
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by short sale pool
    Thanks!
    Yes, but you might want to add a leaf canister (helps to avoid clogging the skimmer line).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Quote Originally Posted by Qwaxalot
    Thanks!
    OK, good advice. Thanks.
    I may end up going with a self powered one/self contained with bag, but can't afford the robot at the moment. We'll see. Might have to see how well a hose connects in the skimmer.
    Jun 2007
    New Jersey
    653
    Thanks!
    I have been plugging straight into the skimmer hole with no plate since 1964 (when we retrofitted a skimmer into our 1946 pool). I don't think they even made skimmer plates in those days--the skimmer itself was cast aluminum. We had to thread an adapter nipple into the bottom to connect the hose. Now they set up the skimmers so you can just put the cuff into the hole and the sleeve there plus the suction will hold the hose in place--no nipple or connector needed.
    If there are a lot of leaves or other junk, I will dump the pump basket when suction drops--usually halfway through is enough. Any more than that, you should have used a leaf rake first.
    Just remember to fill the hose with water first. I just hold it up against a return for 30 seconds or so until the hose sinks along its entire length.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
