Results 1 to 9 of 9
Thread: Pointing the return Down
    Sep 2012
    19
    Does anyone know if and how much you really save when you face the return down when heating your pool?
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Pointing the return Down
    That's the first I've heard of it. But I'm sure others here have knowledge of it!! It does make sense though, because you're not disturbing the surface as much with the return facing down.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Sep 2012
    19
    Also the interaction taking place between the heated and non heated water is longer. If the return is facing up its interacting with unheated water and the air. I wish there was some data out there to know exactly what the savings are. There are some products claiming outrageous savings.
    30,419
    By FAR, the single largest heat loss is radiation into the atmosphere. I have no data but pointing the jets downward seems very insignificant to me.
    Sep 2012
    19
    Think there would be a way to test it? Indoor pool? Think that could be an interesting thing to do....
    30,419
    In my mind, the benefit is so insignificant, it would not be worth the bother to attempt a test of any kind. That said, the forum is always interested in the results if you would like to do the test.
    Jul 2011
    844
    Yeah, I agree about the insignificant difference. I do believe that there is indeed SOME difference due to the increased surface disturbance.
    Bestway SWG
    Sep 2012
    19
    I'll look first to see I can scratch some data up
    I tried it, and noticed a couple of things, one of which was obvious. I pointed one return down, and didn't notice a real difference in water temp. I did, however, notice more junk sitting in that corner that couldn't be directed towards the skimmer.
    I would rather have a cleaner pool as opposed to having a heat loss issue.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
