Results 1 to 9 of 9
Thread: Pentair chlorine feeder 300 29x manual
    San Juan Cosala, Jalisco
    53
    The swimming pool in my development has two of the above. They were recently installed and I don't think they are working as the pool always shows trace or less of Cl. I've checked the Cl in the pool jets coming from the pumps/feeders and they show the same. The management just says they must be working-mind your own business. I've been examing the setup and I wonder if they just haven't got the control dial on the feeders in the right position. There is no manual and I can't find one online that shows how to use this dial. Does anyone know how to operate this dial?
    38,275
    Re: Pentair chlorine feeder 300 29x manual
    No idea how those systems work. From the website:
    Heavy duty 1/2 in. control valve and tubing optimizes flow and erosion to provide larger amounts of sanitizer. Dispenses 8.5 lbs. of 1 in. Trichlor Tablets in 24 hours. Holds 29 large or 237 small tablets. Treats 80,000 to 322,000 gallons.
    Wow ... that is a lot of trichlor
    Here is the manual: http://www.pentairpool.com/pdfs/R24294. ... erComm.pdf
    The question I have is what is the CYA level as it could certainly get too high quickly? Those things should be adding a lot of FC and CYA, but you did not mention the pool size.
    53
    Thanks mod squad. That is the only manual I was able to find for this dispenser but it doesn't go into details of it's operation.
    I think that is the maximum that can be dispensed. You can control how much Cl they put out by varying the number of Cl pucks you put in them (from 1 to 29) and by the volumn of water flowing through the dispensers.
    38,275
    The only adjustments it has are:
    1. How many pucks you put in
    2. How much you open the dial
    States in the Start Up instructions:
    Larger numbers dispense more sanitizer.
    .... and CYA
    53
    The ones we have here have, part way along the tubing, a dial with graduations on it, it says max at one point and you can turn it in either direction but it isn't clear looking at how to use it. I think it controls the rate of water flow through the dispenser.
    Mar 2011
    Scottsdale, AZ
    406
    It is very simple to operate, higher the number the more flow through the tabs.
    So what controls the amount of chlorine dispensed is.
    The amount of flow (control knob), amount of time the pump runs, and the number of tabs that are in the unit.
    Here is the manual.
    http://pentairpool.com/pdfs/R24294.D...FeederComm.pdf
    They can get clogged, and they can be improperly installed so they don't get enough flow.
    53
    Thanks. That's the same manual I've seen. It is just for setup not operation.
    I will take your word for it that the higher the number the higher the flow. When I was looking at it yesterday I didn't have my reading glasses with me. I went back today with my glasses to see if I could make sense of it but they have locked the pump house up. Keeping trouble makers like me out. I tested the pool again and 3 days in a row there is no Cl in the pool or in the incoming jets. So the dispensers aren't working; it could be a number of things; no pucks, water flow turned off (which is what I wanted to check today), hooked up wrong, or ?
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    As mentioned, you need to check the CYA level. Do you have a kit with that test in it?
    You don't mention where you are or how big the pool is either.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Mar 2011
    Scottsdale, AZ
    406
    That is the only manual that comes with it, it is not rocket science, it is a simple chlorine feeder.
    I dont know of of any things made that "0" is higher then "5", just common sense I guess.
    Except those darn refrigerators, is up down, or down up.
    Lucky for you, you don't have to take my word for it.
    After you break in,
    Turn it off, turn dial to "0" remove lid, then turn pump on, and slowly move the the dial up, you will see water increase if it is plumbed right.
    Also a good way to check if it is working.
    Enjoy the break in.
