Results 1 to 11 of 11
Thread: which brand of polyquat?
    Where can I get it? And what brand is good? Thanks.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    Butterfly's Avatar
    South Carolina
    10,045
    Re: which brand of polyquat?
    Any brand as long as the ingredients are "Poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride" at 60% concentration.
    You can call around to see who has it (big box stores ie Lowes & HD, pool stores, etc) or order online.
    You're done SLAMing when:
    Aug 2007
    near the swamp
    806
    nope, this stuff http://store.pinchapenny.com/product/al ... -algaecide
    has to have the 60% after the polyjhkjghfjkhasdjkegkrghjkrthgjkhrtkhgfk listed in the ingredients LOL
    Mar 2007
    San Rafael, CA USA
    12,082
    Kem-Tek Algaecide 60% Concentrated (poly - 60%, other - 40%)
    This okay?
    Mar 2007
    San Rafael, CA USA
    12,082
    [EDIT] Links were broken; now updated MSDS link [END-EDIT] Yes, the MSDS and the label for Kem-Tek Algaecide 60% Concentrated shows that it is the right stuff to use.
    Thanks for the help guys. I bought two quarts of this. Do I add just one quart to my 18k inground pool? http://www.poolgeek.com/GLB-Algimycin-600-P2260.aspx
    Mar 2007
    San Rafael, CA USA
    12,082
    How much you add depends on what you are going to be doing. If you are closing the pool, then you follow the procedure in this post that uses the maximum dosage on the label which is 16 ounces per 10,000 gallons. So 18,000 gallons would be 28.8 ounces so just under 1 quart (so yes, 1 quart should be OK).
    Thanks Chem.
    Jun 2007
    New Jersey
    653
    A fellow by the name of Ben Powell, of poolsolutions.com--well known to all who have been on this site for any length of time, has this info on his site:
    Buckman Laboratories, in Memphis, TN, makes all the polyquat sold in the US, regardless of the label. Arch(HTH), BioLab (Bioguard, Omni, Pool Time, Aqua Chem, Sun, many others), LaPorte (Robarb, etc.) ALL simply repackage -- and possibly, dilute -- what Buckman makes.
    http://www.poolsolutions.com/gd/polyquat.html
    So it really shouldn't make any difference whose Polyquat 60 you buy.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
