Thread: New pool! Test results
    Hello friends,
    We are pleased that our house in The Woodlands Texas closed today. There have been a few days that we were sure we would not get to this point.
    The pool has been maintained by a service that comes once a week and drops pucks into it. Our plan is to utilize the BBB method. I have the pool blue prints and specs but I did not bring them back with me to the condo tonight. We did use our T-1000 test kit. Results as follows
    PH 7.6
    FC 13 ppm
    Chlorine >10
    Total alkalinity 130
    CH 160
    CYA 40
    This was the first time we have ever tested. We tried to be meticulous with the testing. We will test again tomorrow. I will,post those results along with pool specs I find.
    Any comments or suggestions much appreciated.
    Kassie
    Jim
    Intex 15' x 42" -- 4,400 gallons
    installed August 2012
    Intex 2650 sand filter
    TF-100 test kit, BBB method
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: New pool! Test results
    Congrats and welcome to TFP. Nothing alarming in those results, especially for a trichlor dosed pool. Is the pool plaster, vinyl or fiberglass?
    Plaster pool. 12 or 13 years old. Does not look like it has been refinished before. May need to be. Kind of stained I think. I brushed it some today. That improved the staining. Algae,maybe?
    Also, there seems to be a great deal of deposits on some of the tile. Calcium, maybe?
    I will try to post photos and get size specs etc. tomorrow.
    So the numbers aren't too bad?
    Jim
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Algae unlikely with FC of 13, metal staining possibly. Rub the area with a trichlor puck, if it lifts it's organic, if not try a vitamin c tablet to see if it is metal staining. FC is high for a CYA of 40ppm, but that will come down. CH is a little low for a plaster pool. TA is a little high, but unless your PH starts rising frequently, there is no rush to adjust TA.
