Results 1 to 10 of 10
Thread: Probily a silly question.....................
    is there any way i can fit a skimmer to the outside of my Intex pool, instead of using the standard skimmer that you get with it
    Thx
    Gazz
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
    http://s286.photobucket.com/albums/ll82/GazzMan9/
    Wyoming, Michigan
    93
    Re: Probily a silly question.....................
    Quote Originally Posted by GazzMan
    I would say that it depends on whether your pool has the inflatable ring at the top or is the metal frame style with straight walls.
    If you installed a skimmer in a wall with an inflatable ring at the top, you would need to lower the water a couple of inches so it wasn't above the top of the skimmer. The problem here is, the ring rides on the top of the water and there would be nothing to hold the wall up. The other problem here is that the wall curves. The skimmer wouldn't be level like it needs to be for best operation.
    If you have a metal frame pool, I don't see why you couldn't install a standard skimmer. I've installed standard above-ground return fittings in my previous Intex pool without issue. The only thing you might want to consider is adding some additional backing support between the outside of the vinyl wall and the skimmer (maybe stiff rubber, thin plastic, or even sheet metal).
    My 2 cents. For what its worth.
    Tom
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
    Wyoming, Michigan
    93
    Wow! Never seen an Intex built into a deck. Did you cut down the ladder yourself?
    Again, I haven't done it, but based on what I have done I can't see any reason why you couldn't install a normal skimmer in the wall. You could probably even provide some additional support from the deck itself. You would also need to drop the water level some. Normally you want the water level about 3/4 of the way up the skimmer.
    If I was doing it, I would consider something like this:
    I found it here and here for a reasonable price.
    Tom
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    WOW that is awesome for that kind of pool. Thinking about it now, I should have went with that!
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Quote Originally Posted by TomU
    Tom
    yes Tom, i just measured from the bottom of the pool to the deck and cut the excess off
    Thx for yr help matey, ill give them a look
    LULU, do it, it has given us a whole different outlook to the pool
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
    hahahaha.....................iv done it
    yr gonna want to see pics now arnt you all 8)
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
    Butterfly's Avatar
    South Carolina
    10,045
    Of course!
    You're done SLAMing when:
    Here ya go
    the first 18 pics
    the rest of the pics show the evoloution of the pool so far
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
    neat-o!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
