Thread: cannot keep winter cover on OGP
    Jun 2010
    Okeana Ohio
    12
    I have an OBG pool with poly up rights that curve up and out to the edge of the top plate. I tried the covers that use the cable that weaves in and out of each grommet winched as tight as possible without breaking the winch. Even used shrink wrap around the outside edge of the cover and had the cover still blow off ripping the gromets out of the cover. The pool water level was just below the pump return. There was water on top of the cover but it all just moves in the direction of the wind. I live in SW Ohio and do not believe I have any more severe wind that anyone else.
    How do you keep Your OBG pool cover on? Is a cover really worth all the cost and effort?
    Would there be any harm to the pool liner if I just left off the coever? I know it would be more work in the spring if the cover was just left off.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: cannot keep winter cover on OGP
    OGP = ?
    AGP and IGP I understand.
    AGP = Above Ground Pool... does OGP stand for On Ground Pool?
    Jun 2010
    Okeana Ohio
    12
    Yes, stand corrected - sorry for the confussion and my poor typing
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by jcweis1
    LOL - I figured I was missing some nuance and there was a valid distinction. No worries!
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    We have terrible winds here in western Pa. and I found that hanging bleach bottles half full of water from the grommets of the cover worked the best for me. It will bellow up in strong winds, but has never blown off. I think I have about 30 bottles attached to the cover.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
