Results 1 to 7 of 7
Thread: Ok.. here we go... Starting BBB
    Jun 2012
    Escondido, CA.
    42
    We've moved into our new home with pool and have a "pool guy" taking care of the pool over the summer.
    Now that winter is coming .. Im in SoCal so winter is a relative term, Ive decided to start taking car of the pool myself. Thinking that a winter pool has fewer "problems" than a summer pool I might get my feet wet in caring for the pool.. pardon the pun.
    So.. Ive:
    1. Ordered a TF100 test kit..
    2. Starting to hoard chlorine bleach (buying a bottle everytime I go to the store jut to build up a small supply).. sounds like I'll need at least 4 or so to start
    3. Found... "ThePoolCalculator.com"
    But I have some questons...
    How much Borax and Backing Soda should I have on hand to get stated.. say the first month.
    What am I missing..
    Escondido Ca [*]~23000 gallon plaster pool built in the 70's[*]Pentair VF Pump running 10hrs at 1800rpm getting and estimated 35-40 GPM thruput[*]Sta-Rite Cartridge filter
    22,553
    Re: Ok.. here we go... Starting BBB
    You're not missing much.
    Looks like you got a good start.
    I wouldn't get any baking soda or borax right now. You may not need either. Once you get the test kit you can test the water and then you'll know whether you need either or some muriatic acid.
    My guess is the you're going to have to replace some water if the pool guy has been using trichlor tablets.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,113
    Pool School......Forget Baking Soda and Borax for now. I've never used either this year. The biggest item used in the BBB process is knowledge. Knowing what's going into your pool will save you a TON of cash and even more headaches.
    Pool School......it's free!
    Nov 2010
    Calera, Al
    271
    Muratic acid CYA and chlorine are the only thing I have ever added to our water in 2+ years.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Jun 2012
    Escondido, CA.
    42
    Bama.. why would i need to exchange water.. something to do with the CYA from the tablets Im guessing? Why could I not let the pool chemistry come to me Vs chasing it by draining the pool partially.. Does CYA not degrade?
    Can you tell I know enough to be dangerous?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by BitViper
    CYA and Calcium both build up over time.
    22,553
    CYA or CH doesn't go away on it's own. You have to actively do something to get rid of it.
