Thread: Newbie Question: How to access plumbing of inground spa?
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    132
    If (when) an in-ground spillover spa that has a concrete deck around it develops a leak in a pipe, how do you access it?
    Do you pull the spa out? If so, how do you disconnect the suction/return lines?
    ....or are you digging up concrete?
    If digging concrete, would it be better to install a concrete paver deck around the spa?
    I guess my "real" question is: What is the best way to install an in-ground spillover spa to enable access to the spa plumbing?
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Newbie Question: How to access plumbing of inground spa
    So, do you have a spa with a leak, or just trying to think ahead? Really, the only way to do it is digging. Having a paver deck does make this much simpler.
    wpbucher's Avatar
    Feb 2012
    132
    Thanks for the response. I'm just trying to plan ahead. The pool deck will be pavers on top of a 3' wide concrete subdeck. I believe the concrete deck is part of the pool structure (i.e. it is required) of the vinyl pool. Digging through compacted stone is easier than cutting concrete. One issue....I'm not sure if I can adequately compact the stone base if I ran the pavers up to the spa without a concrete deck. Compacting too much would put pressure on side of spa. Perhaps one can't compact adequately....and therefore I will need to expect to reset the pavers immediately adjacent to the spa every few years. .....but that is more of a hardscape question rather than a pool question.
    I think I will try to get the pool builder to minimized the amount of concrete decking around the spa. Install concrete decking that is required by the pool and leave the 1/2 of the spa that is not adjacent to the pool without the decking so that I can install pavers.
