Thread: Question about Polyquat 60
    Mar 2012
    Amarillo, Texas
    341
    I may have this all screwed up. I've been shocking my pool for the last 24 hours. No problem holding chlorine. I added the recommended dosage of polyquat 60 for winterizing my pool last night after dark. This morning I woke up and I failed the OCLT. Do I need to start the shocking process all over or does this have something to do with my addition of polyquat 60?
    FC: 11.5 (brought back up to 14)
    CC: .5
    CYA: 35
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Question about Polyquat 60
    Chlorine slowly oxidizes Polyquat but does so more quickly when both are at higher levels. This is normal so don't worry about the chlorine drop. A chlorine overnight loss test is not appropriate when you are using both for closing. See this post for closing instructions using chlorine and Polyquat.
