Thread: Winterizing – need to lower water level?
    We’ll be winterizing the pool soon and I was told years ago to lower the water level 8” below the tile line. I’ve been hearing conflicting information about this and want to know if it lowering the water is necessary. We get freezing temperatures.
    I/G Concrete w/spa 24k or 30k Gallons (I think lol)
    DE
    Nature2 thingy disabled
    Polaris 280
    Aqualink RS4
    30,405
    Re: Winterizing – need to lower water level?
    How freezing? City and state will be helpful.
    We're in east PA and get ice strong enough to walk on.
    DE
    Polaris 280
    Aqualink RS4
    30,405
    I don't have to close my pool so I will let others help with the details, but, yes, you will need to lower below the skimmers and returns.
    The returns are a good 2+ feet below the tile line and in 37 years we've never dropped the water level that low for winterization. I was just curious why Sylvan said lower the level 8" below the tile line but I was never told why that amount. I had assumed it was to prevent water in the lines from freezing.
    DE
    Polaris 280
    Aqualink RS4
    Dec 2009
    Central Massachusetts
    2,690
    You should lower it to a few inches below the tile. Ice can pop the tiles off here and there. As far as the 8 inhes goes, that depends on if you have a solid or mesh cover. Normally if you have a mesh cover, you will need to pump some water out of the pool at some point to keep water below the tiles before the top freezes over solid. As far as lowering past the returns, you can do that, but it's really not needed. You can blow the lines without issue with the water above the returns and skimmer.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
