Results 1 to 18 of 18
Thread: LED upgrade or stick with Incandescent?
    Feb 2011
    Frisco, Tx
    12
    I am in the process of finalizing the build of my in-ground pool. My question is, should I pay the increase of $2,000 to have two main LEDs and one in the spa or stick with the single 500W incandescent main light and one in the spa? Is the LED option worth it? The builder uses the Zodiac/Jandy WaterColors LED lights.
    My wife is leaning towards it. I am not sold on the upgrade.
    Mike
    PLANNING: 16k gallon 31'x17' free form with 12" raised spa w/16 jets, depth 3.5 x 6 x 4, pebble finish, 5 returns, 2 skimmers, Jandy 60 DE, Intelliflo SVRS, AquaPure SWCG, Jandy PDA PS8 Controller, Jandy Actuator, iAquaLink, Jandy LRZ400 Gas Heater, Polaris 280 w/booster pump, 2 Jandy LED pool light, 1 Jandy LED Spa light, Letro Autofill, Rainbow 320 chlorinator, turbo twist slide, extra bbq gas hookup, hose bibs, sprinkler reroute, 3 Jandy Deckjets, Oklahoma stone spa facing and coping, 3 tier spa face, 625 sq ft aggregate decking, 3 pool benches
    38,262
    Re: LED upgrade or stick with Incandescent?
    Even if you do not get the LED now, I would suggest getting 2 lights put in the pool anyway. Much of that cost is likely just the added niche and install.
    You can always upgrade later then as well. I just put an LED color changing bulb ($250) in my existing fixture. Or you could pull in a full LED fixture.
    One thing about the fixtures is, if they go bad, you have to replace the whole thing. In my case, if the fixture leaks and blows the bulb, I can just throw a new seal and bulb in ... and can revert to the incandescent if I want.
    Jan 2011
    Richmond, Texas
    595
    That sounds way too much. I would look up on the web to see how much they are going for and ask the builder to come down to something reasonable. Look to see the cost difference between the two. There should be no difference in labor and you should be able to bargain with them. BTW - We love our led lights and makes our pool look awesome at night. I would never use regular lights again.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    We just replaced our lights with Intellibrites a few weeks ago. They're amazing. We sit out there and just watch the colors..amazing.
    Flippy is correct. The only difference in price should be the price of the fixtures themselves. The install is the same.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    38,262
    You guys are missing that fact that there is only 1 light in the pool with the incandescent and 2 in the pool with the LED ... so the $2000 includes the installation and wiring of a second niche.
    I would want both niches ... and whether you put in the bulbs or LEDs is a separate decision.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Yep, I missed that, sorry. How big and what shape is the pool? You might be able to get by with just one LED in the pool. I replaced one 500W incandescent with one Intellibrite in the pool (same for the spa, except 300W). With the size of my pool, 2 niches would probably be too much.
    4knights's Avatar
    NE Kansas
    419
    2k sounds insane. List price for the Savi melody lights with transformer (12v LED, 5 colors that change and have modes)- includes 2 lights on 100 ft cords is $1330.00 from the distributor so your PB would be making 600+ just on the lights! Part number is Savi-MEL2PAK. Call Savi for your local distributors name and see if you can get a better deal.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    However, as Jason pointed out, the $2000 includes another light niche. So, $600 for the niche and plumbing to the niche.
    Feb 2011
    Frisco, Tx
    12
    The pool is going to be a freeform 31.5' x 17' sports pool with 3.5'-6'-4.5' depths with a slide at the 4.5' side. There is also a 12" raised spa at the 3.5' side. Volume is 16,000 gallons. I guess since the incandescent is 500W they only put one fixture in the pool. If we go with the LED they recommend two fixtures in the pool. Like Jason says, they will need to add the fixture, labor and plumbing for a second LED.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by mmcaleer
    The freeform part is where the 2nd light (even if not LED) might be helpful for. I have a 16x32 that's 3.5 - 5.75' and one non-LED works great until someone swims in front of it - but with kids that becomes a fun activity - they try to mask off all the light with their bodies for fun...
    Jan 2011
    Richmond, Texas
    595
    Quote Originally Posted by phipsi1237
    I missed that part. I spent too long in the sun today repainting my fence and inhaling spray paint fumes. I would need to see the price difference between the regular lights and the led lights with the extra niche. I know when I asked to have my lights replaced by a pool builder the gave me a quote of 2 grand for two lights not including spa. I ended up doing it myself for WAY less. Each fixture cost me about 400 dollars and I ended up replacing all 3 of them.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Here's a couple of images taken last night. Our pools are about the same size. I'm at about 14.4K. I have one light on the side closest to us in the photos. It would probably be a little brighter, but the niche is slanted down slightly. (I haven't posted photos before using photobucket, so hopefully this is within forum rules.)
    Jan 2011
    Richmond, Texas
    595
    That looks awesome.
    Feb 2011
    Frisco, Tx
    12
    That looks great for only one light. And the reds are usually not as bright as the blues and greens. Nice.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I must confess..... This was taken with a professional camera with an 8 sec exposure. However, it would be even brighter without the landscaping lights in the background (or the fact the niche is pointed down). We chose the purple because that's the wife's favorite.
    My point being, I dont't think 2 lights are necessary in a pool that size. Here's one taken with an iPhone with no flash.
    Another from an iPhone with a flash.
    Pictures can definitely be deceiving. Actually, most are. Just wanted to make sure everyone gets "the picture.". But, you can see in the second photo how the niche is slanted.
    38,262
    I find the reds only reach about half of my pool length and I wish I had 2 lights. Certainly easier and cheaper to do now than try to retrofit.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Feb 2011
    Frisco, Tx
    12
    I ended up changing the quote to two lights. Construction should start in about six weeks.
    4knights's Avatar
    NE Kansas
    419
    I'm not understanding the need for a niche at all, I have Savi melody LEDs and they simply screw into a standard 1 1/2inch return fitting that is attached to 14inches of straight 1 1/2inch conduit then a sweep 90 and conduit the rest of the way to the transformer.
    I can see the hassle for a retrofit but for a new pool the cost is minimal for labor, conduit is dirt cheap and the entire system(2 12v LEDs plus transformer) can be had for around $1400.00
    My lights have 5 colors and can be sync'd or separate, have to figure out the Easytouch panel interface but works fantastic! Wish I would have gotten a third light.
